Go Back   Automotive Forums Car Chat > Toyota > Supra > General
General Discuss anything having to do with Toyota Supra here.
Old 04-30-2003, 08:03 AM
sfenton311's Avatar
sfenton311 sfenton311 is offline
Send a message via AIM to sfenton311 Send a message via MSN to sfenton311 Send a message via Yahoo to sfenton311
Question Turbo on a non Turbo
I was wondering how easy it would be to put one, maybe two turbo's into a stock 93+ non-turbo supra? Is the engine different? would there be as much power as a stock TT? I figured if it was possible it may be better to get a stock non-turbo, because maybe the engine would be less worn, then put turbos on it. Good idea/bad idea?
Old 04-30-2003, 09:04 AM
Amish_kid's Avatar
Amish_kid Amish_kid is offline
Well im not entirely sure on this but I think the block from the n/a cannot take as much power as the TT block also what kinda power you lookin for if you just lookin for 400 or something im pretty sure it will be able to handle it and if you just lookin to break into the three I've heard of some SuperCharger kits that are pretty cheap and with a SuperCharger its instant power but untimately its up to yourself what you want to do b/c with money anything can be done
Old 05-01-2003, 03:23 PM
Supra650RSP's Avatar
Supra650RSP Supra650RSP is offline
Send a message via AIM to Supra650RSP
The engines are different internally. The stock GE will not hold near the power the stock GTE holds. as Amish_Kid rightfully pointed out. In terms of power ya it is possible to produce close to the same numbers as the stock twin turbo but it is the very high HP numbers that make the GTE so popular
1997 RSP Supra
-Single Turbo Conversion (T-66)
-631 rwhp
1995 White Skyline GTR R33
-Single Turbo Conversion (HKS T51R SPL)
-Has yet to see a dyno
Old 05-01-2003, 11:53 PM
Jeepspeed Jeepspeed is offline
Also, the na engine's compression ratio is way to high to hold good boost.
Old 05-02-2003, 12:27 AM
sfenton311's Avatar
Question Compression and Turbos
Whats with the compression ratios and turbo?
Old 05-02-2003, 10:22 AM
Amish_kid's Avatar
Re: Compression and Turbos
Well usually N/a motors run high compression to basically squeeze all the power they can out of them but Turbo usually have to run at lower levels in order to be able to manage boost
Old 05-02-2003, 03:13 PM
D2daT2daM D2daT2daM is offline
listen to this man he knows what hes talkin bout
Old 10-26-2003, 08:20 PM
USA_Ownz's Avatar
USA_Ownz USA_Ownz is offline
YA just look at his avatar that doesn't look like a lier........ hehe
Old 10-28-2003, 04:46 PM
Beef Beef is offline
Re: Turbo on a non Turbo
The only diffences between the 2 are:
Different intake Mani ( GTE inlet is in the front - GE inlet is on the side)
The GE has ACIS the GTE doesnt
The GTE has oil squirter for the pistons the GE doesnt
The GTE has slightly bigger intake ports, BUT the GE's are actually positioned better. Starting higher in the header they have a more straight shot entry to the chamber, no bends equals better flow.
You can make the same amount of power on a GE as the GTE.
The engines are basically the same as far and the rods,crank, piston material, ect
If you but the right mods onto the GE to make it forced induced it will hold the same amount of power in the stock form as a GTE in stock form.
Here is a GE that ran a 10.66@125mph http://speedtoys.com/~daveh/93na-t/
Old 10-28-2003, 04:47 PM
Re: Re: Turbo on a non Turbo
BTW look for the FMAX kit for your GE....
Beef
1986.5 NA MKIII (A/B/A/B/.8)
  • Custom Hard Pipe Intake w/ Cone Filter
  • H4 Conversion
  • TEMS Mod
  • Beef's Fog Light Mod
  • SOGI Short Shift Mod
  • Intrax Springs
  • Illumina IIs
  • NGK Wires w/ Bosch +4s
Email - [email protected]
1973 240Z (Awaiting 2.8T & 5spd)
1982 Toy 4X4 (200k & still running)
1986 Turbo Toy 4x4 (Rare)
1991 Toy 2x4 (Project Turbo Toy looking for 22RE)
If anyone is interested in :
  • 1986.5 MKIII NA (No Title)
    1985 Prelude (No Tiltle)
    1992 Celica (Front End Damage)
Let me know I will sell them CHEAP
Old 11-01-2003, 03:10 PM
Amish_kid's Avatar
Hmm pretty impressive, I've heard also that the cams from the N/A are better suited for Turbo in some situations this right? Because I think I remember someone who had the N/A cams in a Turbo MK3.
Old 11-09-2003, 09:31 AM
RScott RScott is offline
The 2jz-ge is well suited for boost. The owner of the car in the posted link is someone who ive spoken to personally. His motor is a 2jz-ge with STOCK internals with the exception of the headgasket. If running 10's with only a headgasket swap isnt enought to tell you that the motor is strong enough to handle whatever you throw at it, then the knowledge that you think you hold is based in falsehood.
On another note, for you 2jz-ge guys, i have a source for a turbo that is much better than the fmax kit as well as much cheaper. Drop me an email at [email protected]. Be sure to include whether you are 5 speed or automatic as this determines how much power you can run (unless you plan on building the tranny)
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
