Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-25-2003, 10:14 PM
crtolds crtolds is offline
Blower motor good, but fan switch doesn't
Hi.
I'm a newbie with hopefully a fairly easy question. I've got a 1985 Cutlass Supreme. The heater fan on/off/speed control won't make the blower work. When I run 12 volts directly to the blower motor, it works fine. I can't seem to find a fuse for the fan. My question is, is there in fact a fuse somewhere for the blower or will I have to tear into the switch or wiring?
Appreciate any assistance.
Regards, crtolds.
Old 10-26-2003, 08:29 PM
I figured this out, so I thought I'd post the solution in case anyone else encounters the same issue.
I went down to the auto parts and looked at a wiring diagram in an Olds manual. It showed a relay in the blower circuit, so I figured it would more likely be that than a switch.
Went home and dug around and finally found the relay under the hood not far from the blower. I identified it by the purple wire in the small harness connected to the relay, which matched the one going to the blower. I removed the relay and gave it several light whacks with the rubber covered handle of a hammer and reinstalled it. The blower now works fine.
This car has only been driven about 4000 miles in the past 13 years so I can understand why the relay was stuck!
Perhaps someone will find this information useful.
Regards, crtolds.
RESOLVED! 98 99 00 01 02 Rodeo Blower Motor problem wbigsby Rodeo | Passport | MU 2 06-12-2016 10:10 PM
1996 Explorer with blower motor issues CREESERFARM Explorer | Explorer Sport Trac 13 02-03-2011 01:13 PM
06 escape blower fan switch milo42gpw Escape | Maverick | Escape Hybrid 1 03-26-2009 06:38 PM
92 G20 - New heater blower sounds good, but no air! jthomp6395 Express | G Van 3 02-03-2006 11:41 PM
Instructions for Blower Motor resistor and Ignition switch harness BIG-L Grand Prix 4 10-03-2004 07:07 PM
