Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 01-12-2006, 12:19 PM
jthomp6395 jthomp6395 is offline
Question 92 G20 - New heater blower sounds good, but no air!
The blower motor in our G20 conversion van gave out recently, and our local garage replaced it with a rebulit unit. It SOUNDS great, but delivers virtually no air to the dash or heater outlets at the base of the center console. It doesn't matter what setting we have it on - vent, heat, defrost, etc.
The old motor would only come on when it felt ready to after we turn switch on. Finally it came on no more.
The mechanic who installed it said he cannot figure out why. Could a solenoid controlling a vent flap be burned out? Could the heater core be clogged? Prior to the old motor failing everything worked fine, so I don't think our core could suddenly clog coincidentally....
Ideas?
Old 01-13-2006, 09:52 AM
Hollowcreek Hollowcreek is offline
Is the new fan turning ? If its rebuilt, the plastic fan may be damaged where it attached to the motor shaft and not spinning .
Old 01-13-2006, 03:58 PM
Re: 92 G20 - New heater blower sounds good, but no air!
Yes. I pulled the fan body out and ran it to check. It moves a lot of air - got my fingers cold pretty fast holding the edge of the housing. The garage went to a junk yard to look at another old G20 van to see if the cage was the right cage. Apparently there are two types - one with AC one for without. The dealership suggested that the wrong cage type will not move the air. Can anyone confirm? We don't have it back yet to see...
Old 02-03-2006, 11:41 PM
cstageone cstageone is offline
I HAVE THE ANSWER!!!! i HAD THE EXACT SAME PROBLEM 1994 g-20 4.3 A/C AFTER REMOVING DASH AND CHECKING VENTS IN ACTION THEY SEEMED TO OPERATE O.K. REPLACED DASH CONTROL NOTHING SO I GAVE UP AND PARKED IT FOR A FEW WEEKS SO THE OTHER DAY I WAS CLEANING THE GARAGE AND GLANCED AT THE USELESS BLOWER MOTERS OLD AND NEW AND I COULD NOT BELIEVE WHAT I WAS SEEING THE BLADES/IMPELLERS WERE FACING OPPOSITE DIRECTIONS THEN I LOOKED DOWN INTO WERE THE FAN BOLTS TO THE MOTOR AND THERE IS AN ARROW> GOING COUNTER CLOCKWISE ON THE NEW MOTOR WERE THE OLD ONE GOES CLOCKWISE SO THE WHOLE SYSTEM WAS SUCKING AIR UNREEL!! SO I GO BACK TO ADVANCED AUTO PARTS AND THE MOTOR THEY SOLD ME WAS FOR A 12 PASSENGER VAN REVERSE BLOWER I GUESS SO IM VERY HAPPY TO REPORT THAT THE NEW MOTOR GOING CLOCKWISE WORKS LIKE A DREAM NO MORE PROBLEMS!!!!!!!!!!!!!!!!! SORRY FOR MY LACK OF PUNCTUATION I HOPE THIS HELPS SOMEONE STEVE
