Old 10-25-2003, 06:01 PM
dario03 dario03 is offline
110 octane in a car
Would it be safe to put 1 gallon of 110 octane(leaded) or 101 octane(unleaded) with 16 gallons of 87octane(unleaded) into a 2003 Impala LS or any car. If it is, would there be any benifits.
Old 10-25-2003, 08:02 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Re: 110 octane in a car
leaded fuel will trash a catalyst, so no.
if the car is rated for 87 octane, then there will be absolutely no benefit to using higher octane fuel.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 10-25-2003, 08:53 PM
454Casull 454Casull is offline
Re: Re: 110 octane in a car
Listen to this guy.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 11-16-2003, 09:45 PM
JaSeMoney999 JaSeMoney999 is offline
leaded fuel also clogs the o2 sensor so it will not work
Old 11-17-2003, 06:26 PM
JohnnyWash1's Avatar
JohnnyWash1 JohnnyWash1 is offline
Lead was used to raise octane in the past, and no longer necessary in current fuels. Listen to these guys; higher octane only benefits cars that require it.
Jon
Old 11-18-2003, 06:32 PM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
Using higher octane can someitmes rob power too. Higher octane fuels burn slower, and your engine MIGHT not even be able to run on that gas.
ivymike, I thikn there IS a benefit to using higher octane...it keeps your fuel lines and injectors clean (I think)
Old 11-19-2003, 01:43 AM
This is a common misconception. By law, oil companies are required to add the same amount of detergents to all octanes.
Jon
Would you drive a different car than your own? Lionkind Cars in General 0 04-01-2009 07:04 PM
110 octane gas? cky242000 Dirt Bikes 4 03-13-2006 11:36 PM
110 Octane Race Fuel in 454 escort_jay102 C/K 1 04-13-2005 05:05 PM
