| Latest | 0 Rplys |
| Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs |
Show Printable Version | Email this Page |
#1 | |
I was told I was running on 5 cylinders .......
Changed plugs and cap/rotor and still missing at idle..... If I don't see any fouled plugs what do I look for next ?? Any advise or suggestions ?? HB 93 Pathfinder XE 6 4WD |
#2 | |
Is it missing only at idle, or even under throttle?
The reason I ask is my '98 is prone to cloged/dirty injectors. I have had problems 2X already with an injector being so dirty that the affected cylinder was missing consistently at idle and under throttle. The engine was running really rough, even got SES (service engine soon) indicator light on the dash. First time, Nissan dealer flushed the injector under warranty. Told me they would charge me if it happened again. Well it happened again not too long afterward. I gotta admit though that I use the cheapest gas around, though I do use premium. Anyway, I went out and bought Chevron Techron fuel injector cleaner and ran about 1/2 a tank of treated gas through before it got cleaned up enough to take care of the problem. I was running the car with the overdrive off (automatic tranny) to keep the rpm's up to run more treated fuel through the injectors. If you have a manual tranny, just keep the gears low and the rpms higher than you normally would when you drive around. Now I don't wait for the injectors to clog up, I run 3/4 tank (cleaner only treats up to 16 gallons of fuel) of treated fuel every other month to keep the injectors clean. So far, I haven't had any more problems. Hope this helps, and good luck. |
#3 | |
Thanks for your replly......
Hard to tell if it's missing under throttle....... idle is relativly smooth and no "check engine" warnings...... I do use Techron from time to time as well as the German LubroMollly LECTRON and VENTIL ZUBER ...... Will try Techron again and also plan to replace plug wires....... Any other suggestions would be greatly appreciated..... hBar |
#4 | ||
Re: Running On 5 Cylinders ....Help
88 XE V6 4x4, 33x13.50 Swampers, 6" lift, winch, etc etc etc Admin of NPORA, Moderator for NPM, AllNissans.com and NissanHelp.com forums
#5 | ||
Re: Re: Running On 5 Cylinders ....Help
#6 | ||
Replaced plug wires with new Nissan set .......... still missing at idle.....
hBar Quote:
