Old 10-24-2003, 08:54 PM
Hybrid1990crx's Avatar
Can someone explain the difference...
Between OBD1 and OBD2? Im tired of hearing people talk about it and not being able to put in any of my own input.
Old 10-25-2003, 12:10 AM
4drb16civic 4drb16civic is offline
Send a message via AIM to 4drb16civic Send a message via MSN to 4drb16civic
obd1 ecu's are in 95 and older civics, while obd2's are in 96+, if i remember correctly.
Old 10-25-2003, 06:25 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Can someone explain the difference...
>92 = OBD 0
92-95 = OBD I
96-98 = OBD II
99+ = OBD IIb
On Board Diagnostics montiors the engines emissions output, OBD 0 being the least amount of monitoring and restriction, and OBD IIb being the most.
Old 10-25-2003, 03:33 PM
So then for my swap, b16a1 into a 1990 crx, I dont have to change it?
Old 10-25-2003, 03:36 PM
Right, but you may have some other wiring to do, what model CRX is it?
Old 10-25-2003, 04:04 PM
Its a 1990 HF.
Old 10-25-2003, 04:08 PM
Ok good, the HF and the Si are Multi Point Fuel Injection, which means you don't have to do the conversion that a DX owner would, but yo're going to need to get the hubs off a teg or Si civic/rex, since the HF use's a smaller axles and hub, and the B series axles won't fit in them.
Old 10-26-2003, 07:00 AM
So I can still use the b series axles that come with the motor for the swap?
Old 10-26-2003, 08:19 AM
Re: Re: Can someone explain the difference...
You can use them if you change the hub, there's no way around changing the hubs. You have to. The HF axles won't work in the B series tranny and halfshaft, and the B series won't work on th HF hubs
Old 10-26-2003, 08:24 AM
what about knuckles.
Old 10-26-2003, 08:28 AM
The whole thing, the HF knuckle is not compatible with the teg hub. You can however get the whole front suspension off a DX, Si, EX, whatever, as long as it is the same gen as yours, and no a four speed DX or a HF.
Can someone explain the extended warranty on 99 6.5 diesel Ray62406 Silverado 15 11-16-2005 08:55 PM
Can someone explain?? josedi B-Series/Bravo/Bounty/Drifter 5 08-11-2003 04:58 AM
can someone explain flyonthewall General 1 05-02-2002 12:05 AM
Can somebody explain the difference? if any? CiViCtoG20 General 5 03-06-2002 07:08 AM
