Old 10-29-2005, 06:56 PM
Ray62406 Ray62406 is offline
Can someone explain the extended warranty on 99 6.5 diesel
injector pumps. My 99 K3500 is having problems with smoking, belching, and hard start. I am on travelling on the job and my wife is having problems. The last time she drove it it took about 8 miles on the highway before it corrected itself. Once it cleared up it ran great. I replaced the fuel filter and am concerned whether the lift pump or the injector pump is going bad. I am leaning to the injector pump since it does run when smoking so bad, it does not seem to be a fuel delivery problem...
Old 10-30-2005, 09:10 AM
LongIslander26's Avatar
LongIslander26 LongIslander26 is offline
Re: Can someone explain the extended warranty on 99 6.5 diesel
Normally, on a Factory extended warranty, it's the same as the original factory warranty,except you pay a deductible (Like $100.00, unless the repair would've cost less than that) but usually on diesels it's an extended powertrain warranty. (Engine, tranny, etc) that covers the powertrain after the original 36/36 has expired, you just pay a deductible. I don't know what the mileage cutoff is for GM diesels. I know Ford is 100,000 miles. Usually, what one does, the rest do, but you'll have to check your owners manual or call a dealer to be sure.
ASE Certified Automotive Technician
ASE Certified Service Consultant
ASE Certified Parts Specialist
Employed at an Independent Shop
Vehicles:
2005 Silverado LS Crewcab 4X4
1979 GMC 4X4 Jimmy
1977 Chevrolet C20
Old 10-30-2005, 09:29 AM
I received a letter from GM a couple of years ago about a extension on the pump warranty. It was extended to 11 years and 115000 miles if I recall, I am not home so do not have the letter in front of me. The truck has 65000 miles on it. I am hoping a tech will see this and explain if the lift pump is also covered or just the pump assembly itself.
There are no codes being set that turn on the engine light.
Old 10-30-2005, 01:11 PM
Either way you'd have to go to Chevrolet to have it done, you may as well go there and have them run your VIN # and see what's covered.
Vehicles:
1979 GMC 4X4 Jimmy
1977 Chevrolet C20
Old 10-30-2005, 01:30 PM
Sonny01's Avatar
Sonny01 Sonny01 is offline
I have a friend that has a dually diesel and took it in because it was running pretty bad...it cost around $8600.00 for new injectors...does that sound possible?
Old 10-30-2005, 01:47 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Re: Can someone explain the extended warranty on 99 6.5 diesel
Sheeot! Man, he oughtta be able to buy a couple complete drivetrains for $8600!
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 10-30-2005, 01:49 PM
That does sound pretty high to me.
Vehicles:
1979 GMC 4X4 Jimmy
1977 Chevrolet C20
Old 10-30-2005, 02:31 PM
I dont believe it to be injectors unless they are leaking down while sitting. I do know this, before I would pay $8600 for new injectors I would trade it in on a *gasp* FORD.
Old 10-30-2005, 04:07 PM
Re: Re: Re: Can someone explain the extended warranty on 99 6.5 diesel
The Ford diesels have had 10 times more problems than the Duramax, and we're talking some major repairs too. Tons of complaints and recalls.
Vehicles:
1979 GMC 4X4 Jimmy
1977 Chevrolet C20
Old 10-31-2005, 06:09 AM
redneck45 redneck45 is offline
A '99 would not be a Duramax. 8600 for Duramax injectors yes, but not for a 6.5.
Old 10-31-2005, 07:40 PM
Pinecajun Pinecajun is offline
the injector pump on a 6.5 has an extanded warranty from GM on it 11 years 120,000 miles if it is checked by a dealer and found to be the pump it will be totally free as long as you are under the mileage and time . but the dealer has to diag. it and do the pump replacement. they also have to check fuel spefic gravity and a list of other things than call GM for approval to do the pump .
Old 10-31-2005, 07:45 PM
Thanks, thats the answer I was looking for. I'll have the wife get it in for check up....
Old 11-07-2005, 07:37 PM
Thumbs up It is at the dealer now, my thoughts.
Well, I took it to my local dealer this morning and they seemed kind of skeptical about the injection pump being the problem. I got a call this afternoon and they confirmed that the injector pump went tits up and GM is sending a replacement under warranty. It will be ready in a couple of days.
I have taken some heat from my friends about how bad the 6.5 injector problem is and maybe some of it is justified, even I made a tongue in cheek joke about buying a Ford. My personal opinion is that anything can go bad, even new parts. Since GM is taking care of the problem it doesn't seem to be as serious as I envisioned. GM is standing behind its product and that satisfies me totally. It is a little inconvenient but nothing in life is perfect.
This is what will bring me back to the dealer to purchase my next truck and it probably will be another diesel.
Now, the next question, I have looked at some aftermarket heat sinks for the injector control module. Once the truck is returned to me I want to move the module and add the heat sink. WILL THIS VOID MY WARRANTY???? If so I will wait until the warranty expires and add the heat sink.
Old 11-07-2005, 08:05 PM
Well, whatever they called them back in 99, I'm sure they're 100 times more relaible than the Fords.
Vehicles:
1979 GMC 4X4 Jimmy
1977 Chevrolet C20
Old 11-16-2005, 08:42 PM
woodyh61 woodyh61 is offline
Thumbs up
Icannt answer on the extended warraenty ,however there is a web site that has a lot of answers on the 6.2, 6.5 and the new duramax
http://the diesel page.com/ they took a 6.5 dropped the compression, raised the tufrbo boost and a few other and made the 6.5 into 300HP engine, it's all there
