Old 10-24-2003, 03:22 PM
mattd mattd is offline
which relay for auxiliary fan
I have an 89' cherokee and my auxiliary fan is not coming on when the temperature is high. I replaced the sensor and still nothing. I think that it might be a bad relay, but I don't know which one to replace. My Chilton's manual doesn't give a diagram anyone got one?
Old 10-24-2003, 10:48 PM
capt. apathy capt. apathy is offline
I have an '89 also. my auxilary only comes on with the a/c, no matter how hot it gets.
Old 10-24-2003, 11:37 PM
Westy003 Westy003 is offline
Send a message via AIM to Westy003 Send a message via MSN to Westy003
Re: which relay for auxiliary fan
Does anyone know where to get a good after market fan. Also I had same problem with my fan. So I just hard wired a switch inside so when I'm at idle for a while I just turn it on. Don't have ot use it much just in heavy traffic.
Old 10-25-2003, 03:46 AM
I've seen them at knechts for about $60-80(they had several sizes), the sensor for the temp-switch was extra (I'm not sure how much).
Old 02-21-2004, 05:27 PM
cmei cmei is offline
I have an 88 Cherokee. My switch is on the driver side of the radiator. A cable runs back to the harness. When I unplug the sensor and short sensor connector, the fan comes on. Anyone know where I can find a sensor with a temp rating that's closer to 210 degrees? Rumor is the switch doesn't kick in until just under red-line on the temp gauge.
T&C Fan - Replaced Relay - worked for a week - overheating again :-( happyautumn123 Caravan | Voyager 2 07-26-2010 02:39 PM
'85 Calais cooling fan relay location saxonmor Cutlass Series 0 07-07-2010 09:03 PM
96 olds cutlass 3.1 fan relay AK47 SRH420 Cutlass Series 1 04-16-2009 09:33 PM
which relay??!?!?!?!?! 98'nissanowner Altima 2 03-30-2009 10:14 PM
1995 S500 Auxiliary Fan Stays On DioGreer S-Class 0 06-28-2004 12:58 PM
