Old 10-23-2003, 10:29 PM
eclipseracer92 eclipseracer92 is offline
Dirty Headlights
I was just wondering if anybody knows of a good way to clean the inside and out of the headlight lenses. Ive already tried to buff them up real good but it didnt work out as i thought it would. Any suggestions
Old 10-23-2003, 10:35 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
for the outside,
you wetsand them with 1500grit sandpaper, then 2000 grit
the buff them with metal polish, then they'll be blinging
-Agim
Old 10-24-2003, 01:24 AM
KensEclipse KensEclipse is offline
Send a message via ICQ to KensEclipse Send a message via AIM to KensEclipse Send a message via MSN to KensEclipse
I have noticed a lot of eclipse headlights turn yellow after a while, mine being no exception, so I used nail polish remover (acetone) and it took of that yellow nasty film pretty easy.
1991 Mitsubishi Eclipse GS-T
Old 10-24-2003, 09:20 AM
Ive tried the first soultion with the 1500 and 2000 grit sandpaper the outside seems 2 be clean but it looks like it might be on the inside. I no that the headlights are glued together and ive heard of some people putting them in the oven to get them apart and then clean the inside lightly with soap and water then you put it back together. Has anyone done this before cause it doesnt really sound like that good of an idea. Wut temp would u put it on and how long would u cook those bad boyz and wut would u use to glue them back to gether would multi purpose water proof sealent work??????
Old 10-25-2003, 12:10 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
I have seen people boil the headlight in a big pan and it comes apart easily... i'm not sure of the length of time it was in the water but it worked good.
Old 11-20-2003, 05:52 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Dirty Headlights
i just used a hairdrier to crack mine open so i could remove the orange part of the assembly. heat the side away from the blinker slowly and wedge a scwredriver in there. keep heating both sides and slowly applying pressure and it will free up. to put them back together just heat the side with the glue still in it, then place the blinker side in first and close it like scissors, heating the edges so the glue will set again.
Old 11-30-2003, 08:22 PM
EclipsNgirl EclipsNgirl is offline
Send a message via AIM to EclipsNgirl Send a message via Yahoo to EclipsNgirl
Putting them in the oven at about 350 for a few minutes works great. Just make sure you keep checking them every couple minutes, otherwise you'll bake them to death and they'll melt.
Try using Mothers Polish, it works GREAT!!!
98 Eclipse gst-race ready
95 Eclipse gst-stock
92 Eclipse GST-parts car
91 Talon tsi RWD
87 Conquest-our new baby
What do you call the fingerprints on the back of a dirty car? LatentValue Cars in General 1 01-20-2011 02:17 PM
Dirty oil after 900 miles caffeineaholic Caprice 16 12-13-2010 10:56 PM
dirty headlight lenses goosem36 Taurus | Taurus Wagon 1 12-06-2004 05:36 PM
Dirty Headlight lens kelly190 3000GT/Stealth 2 12-21-2003 07:42 PM
dirty headlight Slavik's MAX Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 6 11-15-2002 09:06 AM
