Electrical problem
I have a 92 325I Thats been setting around for a fews years I finally got it running again and now my radio has hardly any volume and my instrument cluster is not fuctioning proper RPM and MPH are allways abouth 1000rpm and 20mph gas and temperture do the same the only time they change if you remove the battery then they bleed down to zero thought on Radio and instrument cluster
Radio and cluster
The radio is most likely a corroded control.
The cluster is most likely a Service Interval battery deal. If the SI batteries are dead the cluster can do some very strange things. SI reset and battery With the ignition switch at (position two) and the engine not running, grounding pin seven #7 of the diagnostic connector to pin one #1 for approximately three (3) seconds will reset the oil service lights. Grounding pin seven #7 to pin one #1 for approximately twelve (12) seconds will do an inspection service reset. http://www.unofficialbmw.com/images/reset1.gif 1. Ground 4. Temperature sensor 7. Reset 8. TDC sensor yellow 9. TDC sensor shield 10.TDC sensor black 11.Start signal 12.Alternator charging excitation voltage 13.Ignition coil 14.Alternator charging supply current 15.Oxygen sensor output to test with. It will signal an oil change need between 5k and 7k depending on your indicated speed since the last reset. It will signal stealer inspections at all the predesignated miles. http://www.eskimo.com/~dalus/bmw/e36/electrical/e36_reset_service_lights.html ![]() SI Board Swap Out Last but not least - the SI Board. Above is a new SI Board with lithium batteries and below is the old one. Note the blown battery on the old SI Board (green circle). The light blue rectangle shows the actual service indicator LED's which appear on your dash display. These LED's are mounted on a separate circuit board which must be pulled out of the old SI Board and plugged into the new one. This is an easy task. The purple arrow shows the orientation of the SI Board relative to the driver. If it fails to reset then you need batteries. Varta battery 500RST OE part. Radio Shack: part number 23-191: $6.49 for set of two; they come w/solder tabs on them. 1.2 volts / 700mAh Charge fully B4 installation on SI board. Consider mounting batteries "remotely" under dash, etc. in separate holder for easy removal in future (i.e. not pulling the console out and apart); you can buy a plastic holder at RS. Run leadwires from holder to SI board connections. Makes life easy if you ever need to replace batteries again. From Radio Shack, get: 1) You'll need a twin AA battery holder ($3) 2) 2 AA NiCAD rechargeable batteries ($6) Later,
Very Useful information!!! Thanks
Thanks for the help replaced SI board cluster working fine now but have another problem had to remove stearing wheel and airbag to get cluster out started car with out the air bag now my SRS light is lit is there a way to reset it with out the tool
