Old 05-09-2009, 02:25 PM
cherokeeowner cherokeeowner is offline
90 Jeep Cherokee Electrical Problem
My 1990 Jeep Cherokee suddenly had the following items stop working: radio, cigarette lighter, a/c blower motor, clock, turn indicators and windshield wipers. However; the following items continue to function perfectly: dash panel lights, interior overhead lights, headlights, brake lights, and hazard lights.
Is it possible that all of the fuses for the non-functioning components would stop working all at once? Or, is there a relay located under the hood that would control all of those components?
Thank you in advance for any suggestions to remedy this situation.
Old 05-09-2009, 02:38 PM
inafogg inafogg is offline
Re: 90 Jeep Cherokee Electrical Problem
have you checked courtesy fuse???
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 05-09-2009, 02:56 PM
I have not checked the courtesy fuse - I am a real novice and did not know that there was such a thing. Is it located on the fuse panel under the dash? (I don't see anything mentioned on the diagram in the owner's manual.)
Old 06-15-2009, 09:10 PM
thetandycollector thetandycollector is offline
Send a message via MSN to thetandycollector
Take out all of the fuses for the affected parts, and see if they've burned. If all are good but the cigarette lighter, take the dash bezel off and check out the wiring bundle that the cigarette lighter wiring travels through... Mine has had a slight meltdown in the past due to the lighter wiring getting hot, melting, and shorting out the wiring in that part of the harness.
There shouldn't be a relay that affects the radio, AC blower motor, cig, and turn lps, but not for sure. I know my 90 Jeep doesn't have one for those.
The Tandy Collector
Old 06-19-2009, 05:37 PM
maurobej maurobej is offline
Please let me know if you fixed your electrical problem. I have a 1994 Cherokee which has the same problem, everything died (ac, wipers, radio, turn signals, except the head lights) now the battery light turns on, and the battery is not recharging, so the car dies after a few days. I had the altenator and battery checked and are good.
Old 09-03-2009, 08:07 AM
LadyZarkia LadyZarkia is offline
Question Re: 90 Jeep Cherokee Electrical Problem
My jeep is doing the same thing and i have noticed that when I jiggle the key sometimes stuff starts working again or at least it use to it got harder and harder to get the key in just the right spot and it vibrates out of place again so that everything stopped working again. I am thinking maybe the lock and tumbler or some where in the ignition is the cause but I am not sure anyone have any ideas?
Old 09-07-2009, 05:07 AM
gtmud gtmud is offline
So this could be a fuse issue, with a possible short in a harness or component. I would check ALL the fuses first with a test light, or by removing them on by one being careful not to mix them up. OF course the 90 had the old style fuse panel under the dash on the drivers side mounted on the firewall. Check the harness as recommended before too.
The key issue, sounds like the ignition switch mounted on the lower portion of the steering column is a problem or the key cylinder and tumblers are binding. Simple test, remove the ignition switch and then try the key cylinder, if it moves free then you have already removed your culprit.
Tags
cherokee , electrical , fuses , relays
