Old 10-23-2003, 12:08 AM
jeevesny17 jeevesny17 is offline
clutch adjustment - 96 integra
Can anyone tell me how to adjust the clutch on my 96 integra? I have to go through about 2 inches of travel on my clutch before it begins to engage, and I'd like to get rid of that play.
Thanks!
Matt
Old 10-23-2003, 04:59 PM
bigben21 bigben21 is offline
Send a message via AIM to bigben21
its hydraulic you cant adjust it check your clutch master cylinder is it getting low on fluid. also look up unde rthe dash with a flashlight at the clutch pedal arm is it shinny like fluid is on if so replace your clutch master cylinder and better replace your clutch slave cylinder to.
Old 01-11-2004, 08:13 PM
Kinked210's Avatar
Kinked210 Kinked210 is offline
Send a message via MSN to Kinked210
Re: clutch adjustment - 96 integra
yeah i got the same problem on my civic...someone told me to check under the dash for loose nuts..
all mine are hella tight and theres plenty of fluid....any suggestions?
Old 01-11-2004, 08:16 PM
lude_si lude_si is offline
yea same problem on my prelude but i think it was do to the shitty driver it used to belong to.
Old 01-12-2004, 11:04 AM
dkhoi dkhoi is offline
I have the clutch problem too. But I dont know where the clutch tension is to increase it. Do anyone of ya know?? Mine is an Integra rs 94
Old 04-21-2004, 10:07 AM
riccimangan riccimangan is offline
on my civic 4th gen(a lot of hondas use the same type engines between about 88-96ish) the clutch cable comes through the bulkhead and down the front of the engine(between the cooling fan and the distrubutor, maybe different on left hand drives) and theres a plastic tensioner screw, tighten it until theres no more slack on the clutch pedal, if you cant find it get someone to press the clutch while you look under the hood and you should spot it.
as i said i've got a civic so there might be differences,
p.s. the reason the clutch slackens like this is normally because the clutch is worn down or the cable has stretched, so have this checked if possible
clutch adjustment judystoy MGB 4 01-24-2004 08:44 PM
clutch adjustment dauto General Discussion 0 06-11-2003 07:54 PM
clutch adjustments soulkeeper '88 - '91 Civic | CRX | Wagon | Shuttlee 2 04-20-2003 08:46 AM
2001 Chevy Prism clutch adjustment Richard Hawley Corolla/Matrix/Voltz 1 10-22-2002 03:29 PM
E36 Clutch adjustment? johanp 3 Series 2 02-17-2002 11:01 PM
