Old 10-22-2003, 11:47 PM
BlackVR-4 BlackVR-4 is offline
Safe boost?
What is the maximum yet totally safe psi to run a completely stock 95 vr-4 turbos with? thanks
Old 10-23-2003, 01:08 AM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
max but safe is gonna be about 15psi, yogs vr4( a well known member on this forum) runs 17psi, but i believe thats cause he made an adjustment, (can't remember what that adjustment is). i run 12 low 15 high.
be safe, don't exceed 15psi
Old 10-23-2003, 01:16 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
I personally didnt run more than 14 when I was stock, 15 is getting a little high and 16 is a no no. I dont know yogs setup but I would assume if he is at 17 he has turbos, and fuel mods. The stock turbos are highly inefficent above 14.
Old 10-23-2003, 03:12 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Yeah - 14 to 15psi is going to be just fine on the stock tubos. The only reason I run a bit more on the Spyder is because I upgraded the fuel system. I haven't upgraded the turbos yet, but they are doing quite well up to 17psi. I'd like to get it on a dyno one of these days and find the optimal amount for its current setup though.
Resistance Is Futile (If < 1ohm)
sr20det safe boost mynismo 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 4 03-04-2004 06:02 PM
max. but safe boost on silvia ozzies15 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 4 11-22-2003 07:03 PM
What is a safe boost on a stock engine? 99TrackerConv Engineering/ Technical 2 03-12-2002 11:44 AM
Max Safe Boost on R33 25T 96GTS25Tii Performance 42 11-14-2001 05:59 PM
safe boost for rb20det?? skyr31 Performance 14 11-14-2001 05:20 PM
