Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 10-10-2003, 10:49 AM
ozzies15 ozzies15 is offline
max. but safe boost on silvia
hi guys, i ve just owned a 01 silvia spec r ( sr20det engine, jap. specs ) i ve hks megaflow intake, blow off valve , split fire platinium spark plugs and 8.5mm igniton wires installed. i want to increase boost but donno what will be the safest boost level on standart engine ? anyone could tell me ?? and also if a get a bleed valve or electronic boost controoler do i neet to change anything (fuel pump, injectors or other stuff ) to prevent engine damage ?? cheers
Old 10-14-2003, 09:51 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
i hope your joking
Old 10-28-2003, 11:59 PM
ChukBzle ChukBzle is offline
I would like to know that too ozzies
Old 11-22-2003, 06:00 PM
multilink multilink is offline
The SRDET's will handle around 224kw(300hp) on standard internals, I have heard that 250kw is the upper limit. The t28 & t28 rollar bearing turbos(s14a & s15) will be reliable up to 14psi, otherwise if you go over the ceramic turbine may come aprt from the turbine shaft. If the t28 ceramic is replaced the turbo will flow well up to about 15psi. It should do 19psi quite reliablebly, but will not be very effiecient & will generate quite a bit of heat. Very strong the srdet's. If you plan on turbocharging a srde(non turbo), you must change the head gastkit, pistons(lower compression from 10:00 to 8:5:1). The srdte also runs sodium cooled exuast valves & oil jets under the pistons for additional cooling.
JJ from Oz
Old 11-22-2003, 06:03 PM
Re: max. but safe boost on silvia
PS from JJ in Oz, I forgot that the fuel system Injectors pump/fule pressure regulator & computer will NEED to be replaced once you exceed 190-200 rear wheel KW. By the way in my last bit of jargon, all power quoted is at the rear wheels & not the flywheel.
Sorry about that.
