Old 10-22-2003, 06:33 PM
pvilleyouthguy pvilleyouthguy is offline
High Idle 92 Voyager
My Voayger gas a 2.5 L engine with a 5 speed transmission. It idles constantly at approx 2200 RPM... sometimes after a long drive it will increase idle speed slightly. I can find no vacuum leaks.
I changed the engine about 20,000 miles ago. It was doing the same thing with the previous engine. I also changed the throttle body.
Any ideas?
Regards,
Ken
Old 12-17-2003, 12:00 AM
daveyhouse daveyhouse is offline
Re: High Idle 92 Voyager
Have your timing checked.
If the distributor or oil pump was removed from this motor at any time the timing may be off. This motor has the distributor running off of the oil pump instead of the cam. If the oil pump rotated a little before or during reinstalation the timing will off. I had the same motor (92 caravan 2.5 w 5speed manual trans) That is what happened to me when I installed a new oil pump. when i was done it would run extremely rich with no power. After two days of head scratching and sore scalp I figured I would move the distributor a little. It worked now it runs fine but idles high especially after coming off the highway the motor is racing. It will settle down a little after sitting a couple of minutes.
But I cannot move the dist anymore without taking it out and turning the oil pump to get the couple more degrees that need to get it right.
2001 Pontiac Grand Am: high idle, high rpm shifting gustie07 Grand AM 16 01-17-2015 02:56 AM
2.7 high and or rough idle hauck Intrepid 6 02-25-2012 11:46 AM
High Idle with New IACV - E150 XLT leroge Econoline 0 01-15-2011 05:21 PM
2002 explorer v8 4wd eb high idle and shifting problem BAKERCONTAINER Explorer | Explorer Sport Trac 0 02-03-2010 01:22 PM
1988 cherokee 4.0L hgih idle/engine tick pstoric83 Cherokee 9 08-05-2009 11:18 PM
