Old 10-20-2003, 09:14 PM
Dan Ward Dan Ward is offline
Check Engine Light
I have a 1989 Chevy Silverado.(350, automatic trans) When it is started up the oil pressure gauge shows about 15 pounds. After the engine gets warm the gauge pressure drops to next to nothing (1 or 2 pounds). The engine runs fine and has plenty of oil. Could the problem be the oil pressure sending unit? If so, where is it and how is it replaced? If not the sending unit, what else could it be?
Old 10-21-2003, 09:02 AM
RABarrett RABarrett is offline
15 pounds sounds a little low. My engine has 250,00 miles on it and has 40 lbs at idle. I would try changing the oil, using the correct viscosity. If htis does not fix the problem, it is possible for the pressure relief valve to be stuck open, causing a bypass condition. Not knowing the mileage and condition of the engine, it is difficult to know. Does the engine make noise? Internal engine wear, such as worn bearings, on either rhe crankshaft or the cam bearings could cteate this condition. The location of the sender is either on the oil filter pedestal or the area directly below the distributor. If you have a gauge, (apparently so,) you will need to replace it with one calibrated for the same gauge as yours. Ray
Old 10-21-2003, 11:00 AM
BOOZER BOOZER is offline
Re: Check Engine Light
First step put a test gague on it, to verify its not a gague/sending unit or wiring problem. If the mechanicle gague reads the same, start getting some prices on a motor! Hope its just a failed sender.
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
