Old 10-20-2003, 09:13 PM
SagxaZefiro SagxaZefiro is offline
Send a message via AIM to SagxaZefiro
Question Different Eclipses. Which to choose?
Hey guys! I'll try to make this as "non-newbie" as possible.
Problem: I want a fast car with cheap performence.
Solution: Buy an Eclipse! (According to research.)
Which Eclipse? I'm currently debating between 2g GS-T and 2g GSX. As we can see here it's the FWD vs. AWD. Normally this would be a no-brainer, right? But I've looked into this, and this is what I've found...
FWD: %10 flywheel to wheel horsepower loss.
AWD: %30 flywheel to wheel horsepower loss.
AWD: 300lbs more in the Eclipse.
Then there's the extra cost for AWD. Is AWD worth the extra weight/horsepower loss/cost?
Thanks guys.
Old 10-20-2003, 09:35 PM
DSM-Owner DSM-Owner is offline
I'D go with GSX. The gs-t will only cause more wheel spin with more HP. Plus GSX will kill any gs-t off the line. If youre looking for brute power off the line go with GSX. If youre looking for a fast highway car then go with GS-T. Both still good cars
Old 10-20-2003, 09:37 PM
kjewer1 kjewer1 is offline
AF - Advisor
AWD is most certainly worth it if off the line acceleration is important to you. The AWD is a couple hundred pounds heavier, but remember that the AWDs are geared lower, which basically cancels that out. I have no problem pulling FWDs on the highway with similar power output, and I absolutely molest them off the line. If you want the most bang for the buck, a 92 AWD TSI or GSX is the way to go. If you want a 2g, the early 2Gs are less money but slightly more prone to the relatively rare crankwalk problem. In my opinion the 92s are the best way to go. MAny of my friends have run mid 12s for a total of 4k invested, and that includes the cost of the car With FWD however, that will be impossible. It takes more power, and more money invested in tires and suspension to even begin to compete on the AWD level. IF you jsut want a car that pulls hard on the highway, then it may be worthwile to save a couple grand and go FWD. But I cant see the point if you have the choice. Hope that helps.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Help me choose my first car bnegri10 Car Buying Q&A 19 08-30-2012 05:27 PM
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd '99EclipseProblems Engine, Transmission and Drivetrain 6 09-13-2009 10:03 PM
Differences between '05 and '06 1.6 Engines? edr_bug Aveo 0 08-06-2009 11:51 PM
95 eclipse gs blue smoke won't start hcruz32 Eclipse Problem Diagnosis 1 03-20-2009 09:36 PM
different Pulleys.... which are good or bad? asnrefugee '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 03-23-2002 10:32 PM
