Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-20-2003, 07:22 PM
hmooblis hmooblis is offline
turbo
what is better for turbo... a b18a or a b18c, no ls/vtec
Old 10-20-2003, 08:43 PM
Noremac Noremac is offline
Send a message via ICQ to Noremac
i believe the b16a for there lower compression
95 ls with GSR head
aem cai, dc sport header, greddy exhaust, pyr computer chip(red-8500) type r pistons, skunk 2 intake manifold and coilovers, aem fuel regulator, msd ignition wires, unorthodox underdrive pulley And Now Skunk2 stage 2 cams but not installed..
all sleepin in a black body...
Old 10-20-2003, 08:46 PM
lets say both their CR were 8:5:1
Old 10-20-2003, 08:57 PM
93weed_eater's Avatar
93weed_eater 93weed_eater is offline
Send a message via AIM to 93weed_eater
the b18a in good condition with "PROPER TUNING" can handle up to 12psi. the b18c and the b16a ( i hope that was a typo man) have higher compression and can't handle as much. but if you're dropping the cr to 8.5:1 on any engine then i might go with the b18c as long as you did forged internals and money wasn't an option but then there is the near perfect rod to stroke ratio of a b16. gees im stumped on this one
LIL HELP HERE
Old 10-20-2003, 09:30 PM
i hear that the b18a is better overall engine even w/o vtec... can someone tell me why
Old 10-20-2003, 09:59 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
The b18a nor the B18B is a better all around motor than the B18C. It is better for turbo apps when you are going to leave the internals stock, it will also hold a bigger hp shot of nitrous than the B18C but for N/A apps the B18C is a better motor. And if you are going to build the internals then the b16 would be a nice choice for turbo, yes the B16 laks torque but with the boost it will have plenty, or yuo could go with the B18C. But personally if money was not an option then I would go with the B16 and have it sleeved with 85mm bore and boost it, you will have close to the same displacement as the B18c and a near perfect R/S ratio, so the life of he motor will be longer.
Turbo Turbo...Im craving Turbo! Cavyfamous97 Cavalier 51 08-14-2007 04:25 PM
LS/VTEC Turbo, H22 TURBO, B20 Turbo....which one? 92HBsi JDM Motor & Parts info/chat 8 01-21-2006 01:11 AM
LS/VTEC Turbo, H22 TURBO, B20 Turbo....which one? 92HBsi N2O | Turbo | Superchargers 5 01-08-2006 10:40 PM
Turbos Turbos Turbos 4-THGENH24LUDE Prelude 8 12-23-2004 04:31 PM
Turbo, Turbo, Turbo SI_CivicGyrl Forced Induction 6 02-18-2004 01:47 PM
