Old 10-20-2003, 06:53 PM
TougeMonkey's Avatar
TougeMonkey TougeMonkey is offline
Send a message via AIM to TougeMonkey
Tryin to remove Rust-o-leum
Rust-o-leum is the worst spray I've ever used, and I knew that...but they were the only ones who had the color I wanted. The first job came out real rough. So I dipped it in CSC for two weeks. All that did was make the paint rough in texture and flat in color.
Anyone had any experiece with removing Rust-o-leum? Any tips are preciated!
Old 10-20-2003, 08:57 PM
jgmodelcars's Avatar
jgmodelcars jgmodelcars is offline
Send a message via AIM to jgmodelcars
well im sure you knew this and i understand your situation but rust-o-leum is meant for metal, so to get it off plastic you can only sand it pretty much or use paint/varnish remover but that will ruin the plastic. that all i know of sorry
My real name is Justin don't be afraid to use it.
Old 10-20-2003, 09:19 PM
specmodeler's Avatar
specmodeler specmodeler is offline
You could try to remove it using brake fluid, castrol super clean, or easy off oven cleaner. Brake fluid is good for lacquers and other paints, castrol super clean is good in removing enamels and acrylics.
Old 10-21-2003, 10:15 AM
Mainomega Mainomega is offline
Re: Tryin to remove Rust-o-leum
Look at the positive side... you're model won't rust.
Got Something Good ? E-mail me
Old 10-21-2003, 11:15 AM
360spider's Avatar
Re: Re: Tryin to remove Rust-o-leum
lol, even if you trow it in garbage, cause I never, ever was able to remove rust-o-leum from plastic.... The only way is sand it off... not sure if you will be able to do this without loosing surface details.
ItalianHorses.net
Old 10-21-2003, 11:53 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
I used Polly S Easy Lift Off (ELO) on some mystery paint years ago.
It worked great on paint that none of the regular methods would touch.
SCCA 7, The lost Z
Old 10-22-2003, 06:44 AM
360spider's Avatar
Rust o leum is etching metal primer - the problem is that it etched the plastic, and nothing, I mean nothing wil be able to remove it. It just becomes part of the plastic - I hope it was gray primer, not dark brown...
ItalianHorses.net
Remove rust spots... RomainDeaMarchi Off-Topic 2 12-01-2004 08:26 AM
What tool to remove rusted shock? sam1drake Grand Marquis 3 11-19-2004 10:56 AM
Removing rust from my 1990 toyota 4x4 el salsero Pick-Up 1 07-02-2004 03:15 AM
removing rust and primer to paint cwmacqueen Camaro Discussions 2 04-14-2004 12:43 AM
