Old 11-30-2004, 12:26 PM
RomainDeaMarchi's Avatar
RomainDeaMarchi RomainDeaMarchi is offline
Remove rust spots...
Does anyone know any good websites where they explain ways to repair rust spots on a car? My 94' Accord winter beater needs a fix up. Thanks. The car is acutally rusted all the way through in some little spots..is this bad rust or oxidation?
"Eclipse tuners are performance obsessed sleeper fanatics who dream only about downpipes, exhaust gases, and wastegates. Their cars aren't pretty, but have ability to spank you silly on the highway. In other words, Eclipse tuners write checks their cars can cash. Mention the word "chrome" and they might drop a boot to your skull."
Old 11-30-2004, 07:39 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Remove rust spots...
cut the rust out , make a patch pannel, weld the pannel on, grind ,smooth,and mold the pannel in, and paint over it....
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 12-01-2004, 08:26 AM
RSLaser RSLaser is offline
If theyre small holes than you can just grind down to bare metal, cut off the rusted edge and BONDO (yes bondo!) it up. Sand down, primer, and paint. Larger holes, yes your gonna need to cut out the area, fabricate or cut the same piece from another car. Clean it good weld it in or have some one do it for you. Primer & Paint.
Hope this gets you started.
1991 Plymouth Laser RS
Only sat for a few years....
