Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-17-2003, 12:00 AM
Turbo Thoughts Turbo Thoughts is offline
Send a message via AIM to Turbo Thoughts Send a message via Yahoo to Turbo Thoughts
Who wants an RB26DETT in thier 240 anyhow.
Man... first things first.
Do your homework. It seems everyone has names and numbers in thier head but no realistic goals or the right know how about the swaps they want.
Reasons to not aim for an RB26DETT:
-The reason RB26DETTs dont drop easily is cause their oil pan is designed to also serve as the front half of the front differential casing.
-ussually buying clips is the most efficient way of getting everything you need for a swap. With all the parts you wont be able to use in an car with an RD26, You'll have to buy one RB26 clip AND an RB25 clip, for the trans, shift linkage, crossmember, and other stuff.
-The RB26 has more piping to rework.. lots of custom stuff... Unless you have the 10K+ to just pull out of your pocket and fork over to a shop and don't mind loosing your car for a few months, you're set.
solutions for those dedicated to an RB26DETT:
-Buy a RB25DET oil pan to replace the 26's differential casing/oil pan
-Source JUST a RB26DETT engine...
-Use an RB25DET clip with a blown motor for the tranny, crossmember and other misc parts.
SUPER SMART EASY ALTERNATIVES (most likely for the uninformed):
-DO AN RB25DET SWAP INSTEAD.
-All you need is the RWD RB25DET clip.. everything you need is included.
-Nearly as good as the 26, it has like 260HP
-the only custom parts NEEDEDis possibly the downpipe, and driveshaft.
-The only highly reccomended part for the COMPLETE swap would be a custom crossmember.
-Its MUCH CHEAPER, ITS NEARLY JUST AS GOOD
Old 10-17-2003, 03:16 AM
stealthj's Avatar
stealthj stealthj is offline
Send a message via AIM to stealthj
Re: Who wants an RB26DETT in thier 240 anyhow.
nice this should be stickied
sorta like a faq kinna thing
BANNED
Old 10-17-2003, 06:54 AM
SR20DETpower SR20DETpower is offline
Banned
Send a message via AIM to SR20DETpower
the only reasong I see a RB as a viable option in a S chassis car is this.......
if you have a ton of money and want a 1000hp drag car with some big ass meats on it.
if you have a ton of money and want 280hp stock that is reliable everyday driver.....
if you have a ton of money and just have to have the RB26 lol.......bandwagon jumpas.....
Old 10-17-2003, 11:12 AM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
i just want a 26 in my car so i can turbo it......
Old 10-17-2003, 12:23 PM
spitz7985 spitz7985 is offline
Send a message via AIM to spitz7985
why get an RB, period?
unless your a drag fag, it really doesn't make sense.
-its heavier, throwing off the nearly perfect weight balence of the car
-unless you're planning on making over 500hp, you can do it with
one of the 4 cylinders
-its a difficult swap
-there was never an RB series engine in the states, so sourcing parts
will be difficult and expensive
-RBs were never meant to go into the s-chassis
i know there are more reasons....can't think right now
don't flame me on this, if you think differently that's great. i'm just posting my opinion. if you want to post yours, don't attack mine.
Old 10-17-2003, 03:39 PM
mrflip69 mrflip69 is offline
More and more support for the RB is coming to the US with the growing popularity of "Import Tuning" so parts are becoming easier and cheaper to come across. Check out Night7's site. He did the RB25 swap and said it actually improved the weight balance of the car -- though the RB26 is heavier, maybe it might bring the scale even closer to 50/50? If not, it should probably just tip it a slight bit, still giving you a pretty balanced car.
Getting 400+hp on the SR, KA, or CA is obviously cheaper, but in the long run, isn't as dependable as the RB-series (like what was said by SR20 on the reliable daily driver... you could probably up it quite a bit more on stock internals without running into problems...)
Theres plenty of ups AND downs to this (and other) swaps. The main thing is the $$$. And since it costs waaaaay more to import a full Skyline to the US, the engine alone is worth its weight in gold. I personally wouldn't mind saving up for this --no matter how long it takes-- Just my opinion...
Think about all the new cars out there. I was quoted around 12k for a full RB26 swap by McKinney Motorsports (throw in a little more for suspension and an LSD and I think you're set)... whereas the STI and other cars in its class run around 30k at the least.
And on that, I wonder if S13GTR ever sold his RB26 (TWIN TURBO) S13 Fastback... Maybe he could fill us in better on why he chose that setup. :P
Old 10-18-2003, 02:26 PM
One-LineDrifter's Avatar
One-LineDrifter One-LineDrifter is offline
Send a message via AIM to One-LineDrifter Send a message via MSN to One-LineDrifter Send a message via Yahoo to One-LineDrifter
non of these pertain to me and im getting a RB25 swap! all i want is about 400 hp although that probly will change once i get there lol but thats my goal for now hehe
Driven Insanity
(O=O/ RPS13 \O=O)
Check out my Ride!!!!!
if nissan motorsports= NISMO
then does honda motorsports=HOMO
"I pitty fools who drives automatic"
Old 10-18-2003, 02:40 PM
klohiq's Avatar
klohiq klohiq is offline
If I had the extra money then I would get an RB26...right now I'm considering an RB25 swap if I do a swap at all. I would prefer an RB26, but the difference is a few thousand and they are both capable of producing more hp than I'll need since my car will be used only on the streets.
Old 10-18-2003, 03:22 PM
grncivicdhr's Avatar
grncivicdhr grncivicdhr is offline
AF Premium User
Send a message via AIM to grncivicdhr
i know its been asked before, but what is the weight of the rb25det compared to a ka24de? i've never payed attention to this stuff before cuz i want a ca18det.
Old 10-18-2003, 03:49 PM
klohiq's Avatar
540 for the ka24 and 720 for the rb25
quite a difference, but much of that difference is in the tranny...so the weight distribution isnt affected much...the only real thing going against rb25 compared to ka-t, ca, and sr is that it adds quite a bit of weight...other than that and price the rb25 kicks ass
Old 10-18-2003, 03:53 PM
The RB25 and 26 are a little bit heavier. But it being "worth it" is an understatement. It's the next best thing to having a Skyline...but even better, its in a 240. We all love the 240s/180s, don't we?
BTW, one line drifter.. I'm oen of the guys who wants a 280HP daily driver .. rip supras on the way to school and work.
Old 10-18-2003, 07:07 PM
240sxRB20 240sxRB20 is offline
IO wont flame you but do you have a RB powered 240?? Do you know the exact weight of the engine or have you looked for parts?? If not, that isnt opinion. That is ignorance. More difficult swap....bwahahahahahaha. The only thing different on the RB25 is the driveshaft issue. Now that the RB26 can be mounted with both turbos, the RB26 just has driveshaft issues. My RB20 slid right in. Tranny and all. Wirng was 8 steps. Everything works. And parts can be ordered on the internet. And more shops are starting to stock RB parts. The more RB users there are, the more parts will be stocked. The same arguement is used on teh KA. Peopel swap bnecause of parts availability on teh KA. Well shit, who wants to lose money making/sto9cking parts for a engien no one tunes??? The more users there are, the more shops will make.
Old 10-18-2003, 10:02 PM
right on man, and props for your swap. I bet its nice, eh?
But this topic is getting stupid, being that people can't keep it straight on the internet. I think it's time to close this thread, since people are getting all whacked out over it and have started namecalling.
So for the sake of the people who's parents raised them in a closet with nothing to cope or deal with, I ask its locked.
Old 10-18-2003, 10:09 PM
stealthj's Avatar
if you have enough money for a rbdet, get that instead of a cadet
trust me
even if the rb25 is gonna be untouched for a while, stock is good
get it, i want that too
BANNED
Old 10-18-2003, 10:18 PM
AF Premium User
nah, i really want the ca18. besides i'm not looking for more than 250hp or so.
anybody want a 91 240?? D-Bo 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 35 12-17-2004 03:17 PM
Got a 240, who want to buy my GT500 ? GT500916 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 15 10-02-2004 11:26 PM
which rims would u want for your 240? eclipse2quick21 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 23 07-28-2004 08:31 PM
Who wants a 95 240? Foxnake42 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 4 09-18-2003 12:13 AM
money, want an s13/240 Hed Trip 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 4 04-07-2003 06:54 PM
Closed Thread
