Old 10-16-2003, 12:37 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Dizzy for my Z6
Hey all you Z6 people, I have a little problem. I have no dizzy for my Z6 that I am about to drop in my crx. I found an si dizzy off an 89, but it doesn't even come close to lining up with the bolt holes on this 94 block. At the junkyard where I got this dizzy, they also had one in a 93 DX. Would I be able to rewire/repin that one to make it work on OBD0? I am seriously hurting here, so any input would be extremely helpful!
(Ami, this is your cue to post up here!)
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 10-16-2003, 09:11 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
you've got to ghetto rig the si to work.. I'll try to find some swap pages taht detail it.. its pretty ghetto...but works.. there is no way to convert the obd1 dizzy..
edit.. here's a pic..
you pretty much have to use only two bolts...and one of them gets a big ass washer to reach the actual dizzy..
SOLD!
Old 10-16-2003, 11:27 AM
91civicDXdude's Avatar
that looks like your timing is way off man. With my Z6 swap, what i had to do was notch the top and front legs of the dizzy, so instead of them having holes, they looked like hooks. Both of my bolts fit fine with no washer, but the back was about 1 1/2" off. Heres a little diagram i came up with.
Old 10-16-2003, 12:52 PM
4GZChatch's Avatar
Re: Dizzy for my Z6
OK, I get it. What did you use to cut the dizzy? I don't have any serious metal working tools... Thanks!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 10-16-2003, 01:02 PM
4GZChatch's Avatar
I just found this on Hybrid's Website:
"Good prices from your local auto yards should start around $500 for at least the block and head. Try to get the VTEC solenoid (around $40 from H.A.P.) and distributor, too. The 92-93 and 94-95 distributors are different, so make sure you get the right one for the head. The 4G distributor can be modified to fit, by drilling the holes bigger. With this mod you lose the ability to adjust the timing by turning the distributor, resulting in a fixed stock timing setting. " Evidently someone has found a way to use the 5th gen dizzy. Any ideas?
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 10-16-2003, 09:00 PM
4GZChatch's Avatar
Re: Dizzy for my Z6
Bump. Anyone out there know about the 5th gen dizzy?
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Cars for the Cure 2009 Pictures Pastapuck Car Shows 0 02-11-2009 11:45 PM
dizzy for ZC? ironman85 '88 - '91 Civic | CRX | Wagon | Shuttlee 4 08-05-2008 03:49 PM
si/hf dizzy for sale 2poor2tune Classifieds 0 04-16-2006 02:11 AM
NEED to buy d16a6 dizzy for mpfi swap DirtyD777 Classifieds 0 05-12-2005 06:20 PM
MPFI & Dizzy for sale 1990civicdxhb Classifieds 3 11-02-2004 03:16 PM
