Old 10-15-2003, 11:28 PM
Lilith Lilith is offline
Unhappy injectors not working
hi
i have a honda civic '94. it had the transmision (automatic) removed, repaired and put back. but now, the car wont work. the injectors arenīt delivering the fuel. we checked everything: fuel presure is ok. ECU is ok.
we poured fuel directly into the combustion chamber and the motor worked.
if you connect a light bulb tu the injectors' cables, itīs supposed to blink as they get signals to open and close to let the fuel pass. well, the bulb stayes ON the whole time - the injectors arenīt opening.
theyīre not clogged either - when we sting any injector, it "spits" a lot of fuel.
what can the problem be? as i said, the injectors seem not to get the order to open to let the fuel pass.
Old 10-16-2003, 08:56 AM
jimmymc jimmymc is offline
Re: injectors not working
I would look for something related to the transmission R&I...pinched/cut wire...loose connector..etc.
jimmymc
Old 11-18-2003, 09:35 AM
shotgun361 shotgun361 is offline
you have probally disconected the crank sensor when removing the trans.without a crank signal the computer doesnt know when to fire the injectors.if you have acess to a scan tool check for cranking rpms
Fuel Injector NOT working SEP Fiero 0 02-29-2004 10:04 PM
92 lumina apv throttle body injectors not working? toalsh Lumina 1 02-16-2004 06:35 PM
injector not working nightdriver09 S-10 2 12-16-2003 05:55 PM
Injectors not working impidemic Cavalier 0 11-10-2003 11:42 AM
injectors not working Lilith Engineering/ Technical 1 10-16-2003 03:07 PM
