Old 10-15-2003, 10:20 PM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
Codes 7 and 16
I know that code 7 is Throttle angle and that code 16 is Fuel injector. How do i fix this problems? TIA
My Name is Roberto AKA. Berto
Old 10-16-2003, 08:15 AM
crxpace crxpace is offline
you need to inspect the area that the ECU is pointing to. I would recommend pulling the wire the is going to the sensor and/or the sensor itself inspect and clean it if possible. Then reset the ECU by disconnecting the battery for about 30 seconds. Then turn on the ignition and look to see if the error codes have cleared if not you may need to replace a sensor. Of do some more inspecting of the areas. I had the same problems and it took awhile now i have no error codes at all. So the ECU will run the ideal MAPS. I hope this helps!
Thanks
Old 10-16-2003, 09:18 AM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Re: Codes 7 and 16
I reset my car's ecu by taking out the hazard fuse for 10-15 secs. I cleared my fuel injector code by using fuel injector cleaner. If that doesn't work I would check the injectors. As for the other code
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 10-16-2003, 02:15 PM
Re: Codes 7 and 16
Thanks
which sensor would that be?
Old 10-17-2003, 12:30 AM
The Throttle Angle Sensor is located on the back of the throttle body it's black plastic i would look to besure the throttle angle sensor is not disconnected, or an open circuit. If all checks out then just replace the faulty throttle angle sensor. The wire will be RED with BLUE stripe.
Now with reference to the injector problem pull out the injectors one by one and clean them with a old tooth brush and some BRAKE CLEAN if the are no cracks and the injectors are good the problem with go away. Don't forget to reset the ECU disconnect the battery for 30 secs. And that's it good luck!
Peace Bro
L59 Z engine code and LM7 T engine code......difference????? wirles Silverado 5 10-04-2010 03:14 PM
1997 Saturn SL2-codes and what they mean emmaandleesmom SC/SL/SW 9 10-02-2009 11:53 AM
2001 Saab 9-5 service soon and code 730 nero11 9-5 0 08-06-2009 08:43 PM
2002 Transmission Codes P700 and P740 rjs0421 2nd Gen 00-05 0 08-04-2009 09:28 AM
fuelpump relay code and lean fuel code fireflya21 Neon | Plymouth Neon 2 09-23-2004 08:40 AM
