Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 09-19-2004, 10:04 PM
fireflya21 fireflya21 is offline
fuelpump relay code and lean fuel code
I have a 96 neon with code 42 and 51. I replaced the fuel pump and it did not help. I can't seem to find a vac. leak. The car runs fine while I excelerate but when you let off the gas it lunges. any ideas???
Old 09-20-2004, 11:47 AM
mprtech mprtech is offline
Re: fuelpump relay code and lean fuel code
Sounds like a air leak. Spray the intake and throttle body with a small water bottle and see if the rpm's change.
Old 09-23-2004, 09:40 AM
Thumbs down
I tryed spraying all the air lines with water and the idle never changed. Is there a better way to check for air leaks? Thanks
