Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 10-15-2003, 08:50 PM
badassaccordriver's Avatar
badassaccordriver badassaccordriver is offline
Send a message via AIM to badassaccordriver
broken CV boot
does anybody know whats all involved in changing/replacing a CV boot on a 95 accord, mines busted and leaking grease all over my rim and suspension. i might just have to break down and take it to a shop, but if theres not too much involved, ill just do it myself. thanks
Old 10-17-2003, 02:40 PM
Jeff C's Avatar
Jeff C Jeff C is offline
Is the axle clicking yet?
There is not too much involved as far as I am concerned. First and for most, you need to be able to get the axle nut off and it has been known to be a major PITA for some people.
-1989 Honda CRX Si, B18A Pic FOR SALE
-1998 Honda Accord EX Sedan 5spd
-1981 Chevrolet Silverado, shaved and bagged Pic
Old 10-20-2003, 05:55 AM
cwoblong cwoblong is offline
Re: broken CV boot
Just change whole axle.Alot easierand alot cleaner.
Old 10-20-2003, 04:36 PM
ra227 ra227 is offline
Yeah I just got the axles changed on my car- 95 civic EX coupe, they were clicking and had been for a while. The CV Boot was completely ripped open so that there were two different sides to the boot- it was of course originally one sealed piece. I would also suggest just changing the whole axle. The hardest part I had was getting the nut and two screws that hold on the brake rotor off and making that damn shield in back of the rotor stop rubbing against the rotor itself . All in all not to difficult though. Just make sure you get good replacement axles. Unless you get a hook-up though, like I did, it is going to cost you to go to a shop. A good price at a shop I checked was $302 and some change for my car. I got it done for $200 even including labor which was only $20 a side- I replaced both cuz both were fucked up bad.
Old 10-20-2003, 08:00 PM
i went ahead and broke down and took it to the mechanic, they did replace the whole axle. thanks for the help.
Old 10-27-2003, 08:41 AM
rico_law78 rico_law78 is offline
hey what's up everybody....well i broke my cv joint too, but mine was making a real real loud "TACK TACK" noise, i mean a real ugly grinding noise...loud! And the car would go up and down a little when it rolled in time with the noise.....the cv boot was broken and grease was leaking out everywhere...
The problem is i was stranded in a national park and had to drive it about 4 miles to get out & call a tow truck. (im in ecuador)
So the question is, did this make the problem worse? Can i just replace the axle and be done with it? Or did this cause major damage to other parts?????
Need to know before i go to the mechanic so i don't get ripped off!!!!!!
thanks in advance!!!!!!!!!!
Old 10-27-2003, 10:34 AM
Jeff C's Avatar
Re: broken CV boot
You shouldnt have done any damage to other parts. As long as the car was still rolling I think that you are alright. Just replace the axle and you should be good to go.
Old 10-27-2003, 10:47 AM
hey jeff, thanks for the reply.....
more or less what would that cost in the us????
also, what about the cv joint itself? is that seperate?
THANKS!!!!
Old 10-27-2003, 11:08 AM
Re: broken CV boot
THANKS!!!!
When I got it qouted at a mechanic is was $302 and some change...but this was for rebuilt axles. New axles would run around $400 or $500 as a rough estimate. I got hooked up from a friend and only ended up paying $200 even for both sides+installation, which was fairly easy.
Old 10-27-2003, 11:30 AM
Jeff C's Avatar
Re: Re: broken CV boot
I buy rebuilt axles from Advance Auto for $60 + core charge ea. and I install them myself. I am not sure what the price is install though. It takes my about 20min to install one.
Old 10-27-2003, 11:36 AM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
20 min?? you are better at it than I... took me proy about an hour thanks to not being able to get the lower ball joint apart. grr...
LS1 RX-7 Zoom Zoom
Old 10-29-2003, 08:25 PM
bambam2000 bambam2000 is offline
Re: broken CV boot
Hey bro I have a question for u. did that tack tack noise came whenever you would turn only? because I got a 88 hatch with a b16a I droped some refurbished axels and the passenger side axel make a tak tka noise when I turn when i'm in gear but if i'm in nutral and I turn it doesn't do it. let me know what up I really need some help.
Old 10-30-2003, 01:52 PM
man mine wasn't even really making that noise, the weird thing is that
mine would do it when i was stopping.
But, you should get that checked out, sounds like the cv joint is about to go, it happens all the time with hondas from what i've heard.
Changing the driveaxle boots on a 944 S2 Dr944S2 924/944/968 0 10-08-2010 02:59 PM
93 Chrysler Imperial with a different but broken Master Cylinder ERPM General Discussion 0 08-04-2009 09:07 AM
Broken Stud Bolts cowgirl97cummins Ram Pickup | Ram SRT10 0 05-28-2009 10:37 AM
Bucket Seat Supports BROKEN! wagslick Silverado 6 02-18-2009 10:58 AM
broken boot greekman Maintenance 12 11-07-2001 11:48 AM
