Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 10-15-2003, 04:44 PM
forest325i forest325i is offline
Question fella's i need your help
i have a 1991 BMW 325i
suggestions for any mods that would increase performance from engine and car in general?
Old 10-15-2003, 09:42 PM
KC Ron Carter KC Ron Carter is offline
You meet BEN, BMW E30 Net?
http://www.bmwe30.net/cgi-bin/datacg...les&Section=03
Best performance for the dollar is the change of the differential to a lower ratio.
Lowers the torque band and makes the car wake up.
BMW does that on every Motorsport built.
$250 and 2 hours is pretty good return.
Later,
Old 10-19-2003, 09:10 PM
7hills 7hills is offline
Another option that is even less expensive: Get a K&N filter for approx. $35 and modify your airbox with ducting made from deforster hose available at the parts store. Use hose with an O.D. of 2 1/4 inches and add an extra hole to the airbox and duct to an opening behing the headlight or create an extra hole in the flat area beside the radiator. Not as trick as a cone filter and an fabricated cold air box, but you will notice an inrease in power and it has a slight increase in intake noise.
need more tourque i need your help!!!!!! marty1 LeSabre 2 02-05-2008 08:51 PM
Who have red top optima on your car I need your help ! Killa Eclipse Problem Diagnosis 20 06-27-2006 10:00 PM
Told my uncle I would help him with his Jetta, now I need your help guys ! 99_Mustang_GT Jetta/Vento/Bora 0 12-28-2003 08:40 PM
Museum need your Help!!!!!! NCMR8CMan@af Corvette 1 01-24-2001 10:01 PM
