Go Back   Automotive Forums Car Chat > Toyota > Land Cruiser/LX470
Old 10-15-2003, 02:51 PM
bigtuna bigtuna is offline
air condioner problem.
The air on my 2001 LC stops blowing cold air. The fans still work but it seems that the compressor stops fuctioning and the cabin fills with the aroma of humidity. The AC will start blowing cold air again if I shut the AC off and turn it back on. This has happened at least 10 times in four (hot) months. I had it to the dealer 3 times but they can find nothing. They did experience the problem but failed to identify or fix it. They did replace the dash mounted temperature sensor but that did nothing. Any ideas on what it may be?
Old 12-06-2003, 08:12 AM
Deckpilot Deckpilot is offline
ac probs
I'm not sure why the dealer wouldn't catch this, unless it is intermittent, but perhaps there is some problem with the compressor clutch operation. It's independent of the fan. That sounds like the direction they were going with the temp sensor. Perhaps turning it off and then on resets the whole system and the clutch begins in the engaged position, then after initial release, fails to engage again.
Old 02-07-2012, 03:19 AM
moeljo moeljo is offline
Re: air condioner problem.
replace the a/c relay.
Old 02-07-2012, 06:48 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
I think it's been fixed 9 years ago...
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
The Following User Says Thank You to Brian R. For This Useful Post:
kyokonitori88 (11-15-2012)
Old 01-03-2013, 12:17 AM
jojnydeep196 jojnydeep196 is offline
Had this problem on my Car. Changed the relay and now the a/c works like a champ! Thanks!
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 08:49 AM
low port on air condioning Big Red 1 Grand AM 4 06-11-2009 10:56 PM
Air condioning swap 1990 Corolla BL54 Corolla/Matrix/Voltz 1 03-01-2006 01:49 PM
Cold air, air conditioning problem BushidoNinja Eclipse 2000+ 6 06-17-2005 07:23 AM
