Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 10-15-2003, 04:10 AM   #1
Jay Beezy
Question Need engine for my Lumina Euro. 3.1 or 3.4?
I need an engine for my 1992 Lumina Euro. It came with the 3.1L engine but I've been thinking about putting in the 3.4L that came in the Z34s. What type of adjustments, if any, would I have to make to get a 3.4 to fit into my car? Also, would there be anything transmission wise that I would need to be concerned with by putting in the 3.4 and the transmission is used to the 3.1? From what I was told, the 3.4 has the same bolt pattern as the 3.1?
Also, in case you all recommend that I stay with the 3.1, do any of you know of a website that I can find an engine for my Lumina? I've been looking all over (including Ebay) and I've found a 3.4 but I want to be sure that I know what I would need to do to put the 3.4 in my car.
I need some info ASAP. My car has been sitting up for about 2 months now and it's driving me crazy!! I need my car!!!
Jay Beezy is offline   Reply With Quote
Old 10-16-2003, 04:47 AM   #2
Jay Beezy
Re: Need engine for my Lumina Euro. 3.1 or 3.4?
Can somebody help me?
Old 10-16-2003, 01:32 PM   #3
RidgeRunner
Send a message via ICQ to RidgeRunner Send a message via AIM to RidgeRunner
Re: Re: Need engine for my Lumina Euro. 3.1 or 3.4?
You'd need the ECM and wiring for the DOHC, all mounting hardware, but I'm not certain about the trans. (It will bolt up and should work) I think all the DOHC engines had the 4T60E from the factory. What's your trans, 4T60 (non-e) I'm assuming?
A word of advice about the DOHC, make sure you change the timing belt often! Every 50k miles isn't a bad idea. Also, there's a pesky little O ring in a plug in the back of the block, if it's leaking, the heads have to come off to fix it properly. Alternators are a major pain to change with the engine in the car, so if you question the alt that comes with the engine (if any?) go get a good lifetime warranty unit for it.
RidgeRunner is offline   Reply With Quote
Old 10-16-2003, 03:39 PM   #4
Jay Beezy
Re: Re: Re: Need engine for my Lumina Euro. 3.1 or 3.4?
I have a compressor, alternator, and starter that are new on my 3.1. Can I use those on the 3.4 or will I need something stronger?
Old 10-16-2003, 07:55 PM   #5
The Burning Rom
Send a message via AIM to The Burning Rom Send a message via MSN to The Burning Rom Send a message via Yahoo to The Burning Rom
Re: Re: Re: Re: Need engine for my Lumina Euro. 3.1 or 3.4?
They should all work..but the alternator may be different. It's not mounted like it is on the 3.1s. It's on the BOTTOM of the engine on the 3.4s. Also...it's a good idea to go with the 4T60E transmission...since the 3.4's ECU (ECM as he put it) is made for the 4T60E.
www.wicgp.com <- Wisconsin Grand Prix Club
1999 Black Grand Prix GT Coupe
1990 Red ASC/Mclaren Grand Prix Turbo Coupe
1990 Metallic Blue & Silver Grand Prix LE Coupe
1979 Blue Dodge Ramcharger
The Burning Rom is offline   Reply With Quote
Old 11-25-2003, 03:29 PM   #6
maybe2fast
stay away from the 3.4 they are a problem engine if you do get it don't drive it hard!
maybe2fast is offline   Reply With Quote
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 01:41 AM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
