Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-14-2003, 08:23 PM
teglsturbo teglsturbo is offline
install a blow off valve
All I want to know is what the vacuum hose on the BOV connect to. I know it connects to the intake manifold, but where? Does anyone have any pictures of what it connects to? They'd be helpful
Old 10-14-2003, 09:00 PM
I have one more question. I hope someone can help me with both of these questions. Does an external wastegate's vacuum hose need to be connected to anything? I heard I'd be able to just leave it open but it doesnt sound right. What do you guys think?
Old 10-16-2003, 11:36 AM
Myjunkistight Myjunkistight is offline
Re: install a blow off valve
You connect the vacuum hose from the bov to the vac. hose coming off your fuel pressure regulator. It's the little roundish spaceship looking thing coming off the fuel rail.
Not sure about the wastegate.
Old 10-16-2003, 06:11 PM
Thanks, I found out the wastegate one should be connected to the FPR vacuum hose too. Does anyone know if its ok to have both of them connected to the same line? Because I would also have to have the FMU connected from there so that would make three things connected form that line, is that ok?
Old 10-16-2003, 06:14 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
Re: Re: install a blow off valve
You can. Connect them to any vac source after the throttle body. My wastegate abd boost gauge are split off one port on the IM, then the wastegate line is also split into the MSD-BTM. My fuel press reg shares the line off the TB with the map sensor. My BOV is split off the brake booster.
Blow off valve, or diverter valve? Chirpn'3rd GTI 3 09-04-2005 07:36 PM
hks blow-off valve installation help cloven 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 1 12-23-2004 08:07 PM
Any way to install a blow-off valve on a n/a engine ? SnakekanS Engineering/ Technical 4 07-19-2004 06:10 AM
Installing blow off valve, HELP! austinbrtndr Off-Topic 5 11-25-2003 01:47 AM
