Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 10-14-2003, 03:20 PM
vaak vaak is offline
Question HELP - Heat only when pressing the gas pedal
1993 Ford Ranger XLT 2WD Standard Cab 4 Cylinder 2.3L
As I have started to use the heat since we're entering the fall season, something strange is happening that hasn't happened in the past. When I turn the heater on, the only time I get heat is when I press the gas pedal (either stopped or driving). If I'm sitting idle, I don't get any heat. For example, if I drive somewhere, I'll have blasting hot heat the whole time I'm driving, but AS SOON AS I stop the truck and sit idling, the heat vanishes to cold air. I don't have A/C on my truck if that simplifies things. I'd like to get this corrected as soon as I can for warming up the truck in the winter and such. Any suggestions?
Thanks in advance...
Chad
Old 10-31-2003, 08:33 AM
EVH5150 EVH5150 is offline
My guess it would be a bad thermostat. My 92 ranger one time blew lukewarm air when I had the heater cranked. Changed the thermostat and started getting hot air again.
Old 11-11-2003, 09:57 PM
stagefright13 stagefright13 is offline
Happened to me in my Ranger and it was just low coolant level. Bad heater at idle.
Gas pedal went to the floor on its own! bagem788 Traverse 8 11-08-2017 06:08 PM
2000 Sonoma Gas Pedal on floor but no acceleration timaugie Sonoma | S-15 0 07-29-2009 02:25 AM
91 escort only runs when i pump the gas pedal hal97321 Escort 1 10-17-2008 09:04 PM
what if I accidently pressed the gas instead of the brake pedal.... m8118 Eclipse 2000+ 6 01-27-2004 08:57 PM
what if I accidently pressed the gas instead of the brake pedal.... m8118 Off-Topic 2 12-27-2003 10:05 PM
