Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 10-13-2003, 04:38 PM
hcgiles hcgiles is offline
Melted plastic switch in front hub
I have an 84 Bronco II. The red plastic switch in the front hub, (the one that you lock it in 4-wheel drive) has melted. MELTED. It is held on by a phillips head screw. It appears that you can just unscrew it and it will pop right off. Yeah, right. I've been told that there is just a spring behind it. I'm afraid that if I unscrew it, all sorts of stuff will fall out. Does anyone have any experience with this?
Old 12-03-2003, 01:53 PM
Sport45 Sport45 is offline
Re: Melted plastic switch in front hub
Sounds like your wheel bearings are fried or your brakes are really dragging. It will all have to come apart in either case. If you want to do it yourself I recommend getting the Ford repair manual or a Haynes manual. Either should walk you through the teardown and reassembly. The plastic part works fine as long as the assembly stays in its normal operating range.
Old 12-03-2003, 01:55 PM
Oh yeah, IIRC nothing comes off but the knob with that first screw. You have to remove a keeper to get to everything else.
front bearing - new or junkyard replacement? gijmcd Sonata 5 02-15-2010 07:15 PM
HELP Tamiya basic putty melted plastic BOOSTD Car Modeling 5 09-18-2003 10:07 PM
melted plastic on stainless steel? Drocca91 Exterior | bodykits | Lighting 3 01-15-2002 02:58 PM
