Old 10-13-2003, 01:53 PM
thcab02 thcab02 is offline
Transmission Swapping
Hi all!
I was wondering, if someone could tell me if I could put a 5-speed transmisson from an '89 2L Accord into a 1.5L automatic '89 Civic Sedan.
And IF so, will there be anymore hardware needed?!?
Thank You.
Old 10-13-2003, 02:09 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
no you cant, get a tranny from a civic, with the same series engine as your civic has. the civic has a d-series motor where the accord has the F in there. find a d-series civic(just about any civic) and get that tranny.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-13-2003, 05:12 PM
Bustamon's Avatar
Bustamon Bustamon is offline
Okay dude, you'll need not only the manual tranny but also a manual ECU, linkage, clutch pedal tree, and also wire the auto tranny harness so that you can take your key out of the ignition and do everything else properly. Its time consuming also and also when doing it be sure to have something around to break because it will make you mad.
1992 Bravada Can I use a different transmission? captainchuckit Bravada 2 03-31-2010 05:27 PM
96 cavalier tranny swap with a 94 sunbird gothmoglord Non-Performance 0 10-22-2009 11:30 PM
1982 b150 transmission swap patch011 Engineering/ Technical 1 06-01-2009 11:12 AM
Auto Transmission swap with Rodeo transmission bibi544 Trooper | SLX | Bighorn | Wizard 4 05-07-2006 11:38 AM
Transmission swap 91g20 Maintenance 2 11-03-2001 08:20 PM
