Old 10-13-2003, 11:10 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Just a crazy idea... but crazy enough, it just might work?
Well, I was screwing around with my CRX the other day, removing some of the AC components, when I got to the compressor... kinda got me thinking about belt-driven compressed air... sounds alot like a super-charger doesn't it?
Anyways, has anyone ever tried to use their AC compressor as a mini supercharger? Would it even work? I think it'd be interesting to find out...
Old 10-13-2003, 11:24 AM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
sounds crazy enough to work try it out worse to worse nothing happens but you could end getting blown if you pull it off
I said getting blown
Old 10-13-2003, 11:30 AM
Posey88cvic4dr's Avatar
Posey88cvic4dr Posey88cvic4dr is offline
Send a message via AIM to Posey88cvic4dr
Everything is worth a try. Give it a shot man.
4g4d4Life <--Link To My Car
TEAM CHOZEN
Old 10-13-2003, 11:38 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: Just a crazy idea... but crazy enough, it just might work?
i dont think it will work for one main reason, it doesnt push enough volume. your engine probably sucks more air on its own. the size of the intake and exhaust piping on a compressor is something like 3/4" and 1/4", and your intake is at least 2". thats a huge difference, but i guess anything is worth a try. its a lot of work though
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 10-13-2003, 12:40 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Re: Re: Just a crazy idea... but crazy enough, it just might work?
What he said. Don't get me wrong... the compressor can keep the pressure up, but the tubing is so small on the a/c system that it does not take very much to do so. And consider that were it not for the a/c expansion valve, the a/c system wouldn't be under very much presure at all.
Honda Enthusiast
Old 10-13-2003, 04:02 PM
D15Bitch's Avatar
D15Bitch D15Bitch is offline
Aaahhh!!!
Agreed, not enough volume, but what if you attached a pipe from your aircon to you intake...
COLD AIR...!!!!!
Maybe worth a try...
Old 10-13-2003, 05:13 PM
ci5ic's Avatar
Well, what if the compressor was plummed into the intake pipe? So that way, the engine is still pulling air through the intake filter, but there's some extra air being forced in as well? That probably wouldn't work either, unless maybe the line was plummed right in next to the TB or something...
Old 10-13-2003, 10:56 PM
Mrock Mrock is offline
Send a message via AIM to Mrock
You took the words right out of my mouth
It makes me curious, I'll admit..but you'd think that people would have found out how to do it by now, right? I think you should try it. I've got an extra compressor lying around the house, I might just give it a shot...
ZC powered '91 CRX...JE 10:1 pistons, Crower rods, Bullfrog cams, Throttle body bored by Gude, Port and polished head, AEM adjustable cam gears, 340cc injectors, MSD SCI ignition, Cold air intake, clutchmaster stage 2 clutch, aluminum flywheel/heavy duty pressure plate, zex nitrous kit.
Waiting to arrive (and install, to get this baby running!)
Walbro fuel pump, PWR radiator, PM7 ECU
Look out, I can run 17's allllll day.
Old 10-13-2003, 11:46 PM
Killa_CRX's Avatar
When Civics Attack!
Nope... still wouldn't work, because the intake manifold would still only be taking in as much air as it needs... when it's pulling more air, it's just going to get it from the closest source available, but air pressure still wouldn't be any higher than what it's supposed to be drawing cause either the flow of air would back wash out of the air intake, or when the engine was drawing more air, what it couldn't get from the hose connected to the a/c compressor, it would just pull in from the intake pipe..
see what I mean?
Honda Enthusiast
Old 10-14-2003, 12:05 AM
91civicDXdude's Avatar
i think the benefits gained will be outweighed by the draw of the compressor.
Old 10-14-2003, 11:37 AM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
At the refinery I worked at, there was a vacuum device attached to a barrel that we used to vacuum up serious dirt. It ran off of compressed air.
There was a nozzle inside a pipe. Compressed air line was hooked up to the nozzle which sprayed pressurized air through the pipe. This air squirting through the pipe created the vacuum which SUCKED other air in, which ran the device.
No moving parts, either.
If you could stick a nozzle shooting compressed air into the intake, it would create MORE vacuum (I know it sounds like you're violating the laws of physics, creating vacuum by squirting pressurized air) inside the intake, and suck more air through the filter into the engine.
I doubt it would work with the AC components, because they have to be very, very clean, plus they need some oil circulation. That oil would just get sucked into the engine, and the compressor would be toasted very quickly...
Work on it. Find a nozzle that you could run inside the CAI pipe. I do think there's a valuable idea that's do-able with the components most of us have just laying around.
Flunky
Old 10-14-2003, 11:58 AM
redmanjd redmanjd is offline
people do that for air ride suspension
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 10-14-2003, 12:16 PM
D15Bitch's Avatar
Yeah, we all agree that the volume would not be enough, but what about leading the cold air from your aircon to your throttle body, maybe not more air, but COLDER air...
Old 10-14-2003, 02:19 PM
Killa_CRX's Avatar
When Civics Attack!
Flunky
Shooting the extra compressed air into the intake would have the effect of back washing back out the intake pipe unless you had some way to actually force the compressed air into the intake manifold directly... but by doing so you'd be cutting off all other air coming into the intake system, save that from the compressed air you're forcing into the intake manifold... so once you run out of compressed air, no more internal combustion, right?
As for the hooking an a/c hose that would normally go inside the car and cool the car off inside up to the intake manifold piping... the air coming out of the a/c hose wouldn't be cold enough to make any real difference, as opposed to the 30-40hp your a/c compressor would be sapping off the engine to run itself.
One option would be some type of air expansion valve like the a/c system uses to create the actual cold air. But with that, you'd need some kind of oil charge running inside the system to keep the air running smoothly through the expansion valve without clogging or over heating... which that couldn't be good to shoot an oil charge like that into the intake manifold, now would it?
But even with this, you're getting closer to the idea of just using an NČO kit.
Honda Enthusiast
Old 10-14-2003, 09:56 PM
to which i again say...
crazy idea but u gotta read? Toro01 Car Audio 5 04-18-2005 04:09 PM
Crazy idea so stupid it just may work Savage Messiah Camaro Discussions 11 11-12-2004 12:12 PM
a wacky idea that just might work clmp75 Town Car 3 10-10-2004 09:39 PM
The Chopper's Resource - Just another crazy idea... Alex5390 Graphic Manipulation 18 02-12-2004 03:49 AM
This is just an idea but would detailed design sheets help anyone? chrismcgee Car Modeling 25 05-21-2003 05:07 PM
