Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 10-11-2003, 07:47 PM
youngdrifter_x's Avatar
youngdrifter_x youngdrifter_x is offline
Send a message via AIM to youngdrifter_x Send a message via Yahoo to youngdrifter_x
**Problem here need help**
I have a question while my dad is driving his car it seems to stall while you put in it in neutral. It turns off. If anyone has any answers please post. Thanks
-Andrew R.
Old 10-12-2003, 12:09 AM
Okay..
Well earlier I was pressing gas in neutral and i took it up to about 4500 rpm and the car shut off after that. Is that normal?
-Andrew R.
Old 10-12-2003, 02:05 AM
RalphCare RalphCare is offline
Re: **Problem here need help**
Originally Posted by youngdrifter_x
Okay..
i believe someone else had the same problem in another board.
its either ur
MAFS not working correctly.
ur ECU being wired wrong.
or ur fuel pump isnt pumping enuff fuel, u must get a walbro or atleast a 255 litre per hour pump.
ur compression will be really high if u dont. my friend ran his engine like this for a bit and sorta leaned it out. it didnt perform that well after that, but he fixed it up again and it was running ok.
ill look on the other boards and see if i come up with anyhting.
NO, it aint my car in the sig, but i like it. so STFU - BIATCH!.
I need to make websites for a college portfolio for graphic/webdesign courses. please hit me up if u need a website and will make a really sweet deal. and my work is guaranteed.
Old 10-12-2003, 05:36 PM
mynismo mynismo is offline
yada yada yada
Send a message via AIM to mynismo
Re: Re: **Problem here need help**
you dont' need a walbro unless you're running nos or have a high capacity engine, otherwise it will just put a slit in your wallet for the extra gas going to your car that's not beneficial at all.
that may be the prob... just find a used fuel pump that works good, $20 or so
438whp / 373tq - 11.9 @ 126
Old 10-12-2003, 08:32 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
Hi
(The car only stalls when it idles right? If so then keep reading)
I had a similar problem w/ my stanza (yeah I almost rebuilt the whole car ) anyway I pretty sure it is one of your vacuum lines! Check for cracked or shaky vacuum hoses.
I even replaced the ECU on the car by my self, when that did not work I changed the air sensor!! That was not it too, finally I took it to the dealer were the put a stopper in one of the lines and it ran like new!
Good luck!
Old 10-12-2003, 08:40 PM
Is stalls while when i'm driving too. thanks guys i'll try it
-Andrew R.
Newbie here! Need help with Painting! skh_austin Car Modeling 2 09-30-2002 12:51 AM
New Here.....Need Some Advice... FlyOrDieRacing '88 - '91 Civic | CRX | Wagon | Shuttlee 1 06-28-2002 12:17 PM
Anyone know anything about nissans here? need help IntegraTypeR 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 4 04-20-2002 10:28 PM
Hey noob here.....need some info on these great cars Kabs RX-7 24 01-16-2002 04:02 PM
New here, Need ome help habebhma Engine 7 11-30-2001 04:51 PM
