Old 10-11-2003, 04:33 PM
nmn54 nmn54 is offline
Flip Up Light Problem
I was driving on the freeway and had to get onto another road and went down to enter and went through a big puddle of water and the water splashed up about six feet high. Then when I got to my destination I turned my lights off because they were on because it was raining and dark. Then when they went down the driver side light started making a noise a loud one for about six seconds. It's like it is the motor or something I was just wondering if anyone has had this problem. Also when I don't even turn my lights on but get out of my car and lock my doors electrically they will come up and go down and make the noise again. If I lock my door manually they will not make this noise. I was just wondering if anyone has had this problem and if there is anyway to fix it because I see other Firebirds who just have their lights up but no lights on so do they just go out or something. Also does anybody know of any good scratch remover or something that can fix bad scratches.
Old 10-11-2003, 04:46 PM
I found a cool page that shows a way that might fix the problem if anyone else is having this problem.
http://www.bfranker.badz28.com/headlightfix/#FreeGuide
Old 10-11-2003, 06:44 PM
BlkCamaroSS's Avatar
BlkCamaroSS BlkCamaroSS is offline
Send a message via AIM to BlkCamaroSS
That's the fix I was gonna suggest for you...
2001 Camaro SS #2239 of 6332
1/4 mile time: 13.575 @ 105.55 mph, 60' time: 2.276
307.1 rwhp, 330.1 rwtq = 353.2 hp, 379.5 lb ft torque
Options: SLP Front Grille w/ SS Center Logo, 17" ZR1 Chrome rims, 6 speed, Hurst Short Throw Shifter, Monsoon 500 Watt Sound System, T-tops, 1LE Performance Suspension
Mods: Holley PS Air Filter, SLP Air Box Lid w/ Mr. Ed's pipe fix, SLP CAI, SLP Bellows, SLP LM, SLP Y-pipe, SLP 160 Thermo, SLP Temp Module, SLP STB, KBDD SFC
Old 10-16-2003, 01:20 AM
AnotherBreedRacing AnotherBreedRacing is offline
Send a message via AIM to AnotherBreedRacing
firebirds aare know for there flip light motors goin the have hand cranks installed form the factory for this reason with the eletric locking problems check your wireing and security stuff btu the motors are madd exspensive so i would try anyway possiable to find the right problem
Old 11-16-2003, 09:19 AM
rgh1950 rgh1950 is offline
Re: Flip Up Light Problem
I have the same exact problem--What actually fixed your problem. Mine is a 1999 model. My problem also started after driving in the rain--both lights. same problem with the door locks and remote
Thanks
rgh
Old 11-16-2003, 02:39 PM
89birdowner 89birdowner is offline
if you have to buy new motors, go to a junkyard. it will be A LOT cheaper. but make sure you find a junkyard that offers a warranty so if they don't work you can take them back. i have an 89 bird and when i bought it the wires to the motors were cut at the motor. at the junk yard i picked up both for $100 as opposed to $222 each from GM. just think about it. and they are somewhat easy to replace takes about 30minutes per side.
Old 11-16-2003, 07:01 PM
BadAzz240's Avatar
BadAzz240 BadAzz240 is offline
Send a message via Yahoo to BadAzz240
Well, in the case of my friend that "free" fix didnt work but the motor itself was ok he just needed a new gear and he actually found a place online to order a lightweight brass gear or something, as opposed to the cheapy plastic one GM puts in there. See if you can find something like that. Or like they said above just go to a junkyard take one of the motors apart and pocket the gear, cuz that may be all you need...
Just for the Stroke of it...
Old 11-17-2003, 06:18 AM
Thanks to both of you for responding>>
I understand about the gears, getting worn and not sensing when the light doors are down, but what does that have to do with the light doors going up and down, when the door locks and the remote is used when locking the car door?????
Son in law works in a junk yard---much cheaper that way :-)
Old 11-17-2003, 02:01 PM
Dalusa's Avatar
Dalusa Dalusa is offline
Send a message via AIM to Dalusa
someone makes a metal gear for the headlights but i forgot the name of the company im sure you could find it if you looked for it!
______________________________________
Best 1/4 mile time 12.68 @ 128mph
386HP 373Torque
Options:Sport Metallic Gold Ws6 Manual
Mods: Hooker competetion headers, Slp y-pipe, Slp LoudMouth Catback, b&m Short Throw, March Pully's, 80mm Throttle Body, Weiand Intake Manifold, Jet stage 2 chip, Slp 160 Thermo, Eibach pro kit, Slotted Rotors (F&B), Granatelli MAF, A-Pillar Guages-(Air/fuel Ratio, Fule Pressure, Trans Temp) Slp Skip Shift, Granatelli - Panhard Rod, G Load brace, subframe Connectiors, Strut Tower Brace, 200 MPH speedo, AFS ZR-1 Wheels (17X9.5-F 17X11-B) Sumitomo HTRZ Tires, Wings West ground Effects (Front only) E-mail or AIM for Dyno Sheet
Old 11-17-2003, 08:03 PM
lizabethbaker lizabethbaker is offline
Send a message via AIM to lizabethbaker Send a message via Yahoo to lizabethbaker
Costs $81 to do both headlights, I suggest buying 2 new motors and installing dude's nifty little brass gears before installing the new motors (took me an hour and 25 minutes to do both! and I'm a ditzy blonde!!)
Old 11-17-2003, 08:09 PM
BadAzz240's Avatar
Re: Re: Flip Up Light Problem
Your headlights are going up and down when u hit the remote for the alarm? Well, is it an aftermarket alarm??? If so then who ever hooked it up, hooked it up to the headlights and not the foglights, so it flashes the heaflights when you click the alarm thats why they come up. On my TA its hooked to the fog lights so the fog lights flash when i click the alarm, and NOT the headlights... If it is the stock alarm then I say it must be wired wrong... This is my only guess...
Dash Lights & Battery Light LilBitEG Explorer | Explorer Sport Trac 2 09-10-2010 06:47 AM
Brake lights problem corollastudent Corolla/Matrix/Voltz 1 07-20-2009 12:39 PM
Trunk light problem sudaloo Sephia 0 06-12-2009 10:42 AM
Flip Light conversion on 1g Eclipse nkoenig Off-Topic 1 07-04-2003 12:31 PM
