Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-13-2010, 07:01 PM
LilBitEG LilBitEG is offline
Send a message via AIM to LilBitEG Send a message via Yahoo to LilBitEG
Dash Lights & Battery Light
I just bought a 95 Explorer and there are a couple of things I need to get done. The lights on the left side of my dash and steering wheel won't light and the battery light keeps flashing on and off when the lights are on. I put a new battery in it the other day and had the alternator tested when it was installed and was told it was fine. Where should I start? Fuses or? Thanks.
Old 09-10-2010, 03:10 AM
fomoco1912 fomoco1912 is offline
Re: Dash Lights & Battery Light
You need to remove the instrument panel and change the main bulbs which the black one's and make sure you disconnect the gear shift indicator wire from under the dash so you don't brake it .
Old 09-10-2010, 06:47 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
I think FoMoCo has you covered on the bulbs. For the flashing battery light I'd suggest you first make sure all the wiring between the alternator and battery is clean and tight, not just the power wires but also the ground cable from battery to chassis/engine block. Make sure the connection to the fuse/relay distribution block is also clean and tight. If that doesn't fix the light, then you might need to get out the multimeter and test the charging system under varying conditions, particularly when starting. On more than one occasion I've experienced those quick testers stating a battery or alternator is good when in actual use it proves out otherwise.
-Rod
Tags
dash , electrical , lights , problem
