Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-09-2003, 01:45 PM
sbalgach sbalgach is offline
'88 Camry W/ Brake Fluid Leak
Here's the problem. I have an '88 Camry with a break fluid leak INSIDE THE CAR ???
The master cylinder seems OK and the car stops fine except for a small amount of "pulsating" in the pedel.
The fluid level goes down slowly. This weekend I looked under the dash and the mat and lower valance panel was saturated with brake fluid !?
Is the leak from the master cylinder or the break booster seals??
How much of a hassle is this situation to fix? (I'm very mechanical)
Thanks for any help.
Steve
Old 10-18-2003, 03:03 PM
sidler73 sidler73 is offline
Master cylinder
The leak is coming from the master cylinder......it is running down the plunger onto the break pedal top and down the inside to the floor area.
It requires a bit of "upside down" maneuvering .....but is not difficult to fix.....just replace the master cyliner.....done!
Old 10-20-2003, 08:06 AM
Re: Master cylinder
Thanks for your help. I was beginning to wonder if anyone reads this forum.
I'll change the master cylinder.
Old 10-20-2003, 12:38 PM
Thumbs up You are welcome
Enjoy and if you run into anything else let me know.
www.offroadaction.8k.com
http://community.webshots.com/user/offroadaction
2000 Windstar transmission fluid leak olopezm Windstar 16 09-17-2010 08:51 PM
Brake fluid leak john3mo Lumina 3 11-16-2009 03:28 PM
96 camry powersteering fluid leak bz2fx8 Camry/Camry Hybrid/Vista 5 02-06-2006 12:55 PM
1992 Camry brake fluid loss reveller Camry/Camry Hybrid/Vista 3 03-20-2004 08:46 PM
