Go Back   Automotive Forums .com Car Chat > Toyota > Tacoma
Old 10-09-2003, 01:43 PM   #1
shempdevil
Question My fan won't run...99 tacoma prerunner
Hey...
I have a V-6 1999 Tacoma prerunner.
It just turned 65000 miles and I hava a problem.
The fan won't run.
I checked the fuse and it's good.
That is, if I am looking at the right fuse...#9.
In the fuse diagram in the manual, it doesn't specify which fuse the fan is on.
Anyway, I figured I would check the wiring but I can't find a wiring diagram...or even an engine compartment diagram.
The same thing happened about 6 months ago...I checked the fuse, shut the hood, and then the fan started working.
No problems since...until now.
Everything else works...all controls, lights radio, etc.
That's why I am pretty sure it is either the fan, itself...or the wiring.
Any advice or any leads to finding diagrams would be greatly appreciated.
Thanks
Matt
shempdevil is offline   Reply With Quote
Old 10-09-2003, 03:07 PM   #2
shempdevil
Update on fan
I went out and inspected the wiring the best I could and jiggled it around a bit hoping that if there was a short, I would bend the wire just right and the fan would run.
I started the truck and still nothing...
Then I moved the air intake knob back and forth between fresh air and recirculate.
When I did this, the fan came on and stayed on like nothing ever happened.
Heater, Air Conditioning Fan won't run camsgram Eclipse Problem Diagnosis 2 08-30-2006 09:51 PM
Radiator fan won't run? jms92 LeSabre 9 10-25-2005 07:26 PM
Cooling fans won't run dantatara Venture 11 06-27-2005 01:50 PM
'99 radiator fan won't run Wrongway Caravan | Voyager 1 09-07-2004 08:41 PM
cooling fan won't run century_hell Century 5 08-25-2004 09:48 PM
