Go Back   Automotive Forums Car Chat > Buick > Century
Old 08-21-2004, 03:20 PM
century_hell century_hell is offline
Angry cooling fan won't run
The top hose on the cooling system blew and we replaced it. Apparently that was not the root problem. The cooling fan refuses to start and the car just overheats again.
Thermostat?
fan motor?
test this?
What else?
Old 08-21-2004, 03:35 PM
public's Avatar
public public is offline
Re: cooling fan won't run
Temp sending unit and the fan relay need to be tested or replaced.
Old 08-21-2004, 04:01 PM
can you tell me how to test the temp sending unit and fan relay or direct me to someone/something that can?
Old 08-21-2004, 04:22 PM
public's Avatar
A Haynes manual will give you the specs for the sending unit, usually with a multi meter checking for ohms within a range. The relay can be checked for continuity and check for the output voltage when closed. Again a Haynes or Chilton manual would be very helpful. Most any parts store would have one for this car.
Old 08-21-2004, 04:28 PM
Thanks so much
Old 08-25-2004, 08:48 PM
public's Avatar
Did this information help?
