Old 10-09-2003, 08:13 AM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
Boyd's Paints?
Has anyone tried these paints? I saw them at Wal-Mart, and wal-mart didn't have any blue's in smaller ones that I could airbrush, so I bought one, and I was wondering if its a good paint. It was $5 so I'm guessing it is, but just wanted to see what people that have used it before thought of it. And any tips on useing it? Thanks for taking the time to read this, any help will be much appreciated.
Old 10-09-2003, 09:15 AM
CADguy's Avatar
CADguy CADguy is offline
I used Boyd's Purple Pearl on my 1964 Impala seen here:
http://www.automotiveforums.com/vbul...d.php?t=141103
It went on better than regular Testors spray cans. But was more tempermental than Tamiyas sprays. Its about in-between i would say.
I needed 2 cans on that land-yacht impala though.
Try some.
Matt
Old 10-09-2003, 09:48 AM
gundam1969's Avatar
gundam1969 gundam1969 is offline
AF Vendor
Send a message via AIM to gundam1969
I've also bought a couple of these paints, but have been reluctant use them as i'm unsure which clear lacquer to use over them. Testors clear is hard to get hold of in the UK, so I was thinking of trying TAMIYA clear.
Has anyone tried this?
Cheers.
Old 10-09-2003, 11:08 AM
supratuner's Avatar
Boyds is really good paint, a lot better than regular testors. I almost always use it.
One tip would probably be to buy two of the cans, the bad thing about the paint is that it takes a good 2-3 coats to really cover a car, with testors one coat will really cover every thing up, im not sure if other people reading this thinks i make sence, but if you were with me when i paint, i would show you what i mean.
Old 10-09-2003, 11:12 AM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
I like em
heres a custom mix of alumacoupe yellow and Lime Pearl
Old 10-09-2003, 04:43 PM
EMAXX's Avatar
Re: Boyd's Paints?
I only got one. Dang it. Does anyone think that I can cover my entire Revell Silverado with one can? This kind of blows. With one Tamyia, you can almost do about 3 cars, and the chassis. Thanks for all the help guys.
That green looks wicked awesome!! Great work on it man.
Old 10-09-2003, 04:54 PM
dag65's Avatar
Re: Re: Boyd's Paints?
Thanks E, you could do a base coat of silver or gold underneath to help with coverage
Old 10-09-2003, 09:07 PM
supratuner's Avatar
Re: Re: Re: Boyd's Paints?
Damn straight,
Im pretty sure you cant get the entire Silverado covered with one can, I might be wrong, i barely had any left over with a Revell Civic. so im not really sure. Good luck!
Old 10-09-2003, 10:30 PM
jgmodelcars's Avatar
jgmodelcars jgmodelcars is offline
Send a message via AIM to jgmodelcars
i've used boyds
boyds goes on alright, it just takes a lot to cover like everyone's been saying so if you do a base coat of white or light blue it will help a lot good luck
My real name is Justin don't be afraid to use it.
Old 10-10-2003, 07:50 AM
EMAXX's Avatar
Re: i've used boyds
Ok, thanks guys. Do you guys think a base coat of silver would look good? I have a ton of silver that I've never used, and I think a silver and blue would look pretty good. How would I do the base coat though. Do I just do it like You just paint normaly? a few light sprays, then a thick one, or would I do it someother way? Thanks for all your help guys. I'm sorry I sound like a noob, I'm just not good at painting.
Old 10-10-2003, 10:27 AM
008's Avatar
008 008 is offline
Re: Re: i've used boyds
As long as your base coat is an even color you'll be good. I just use plain gray or black primer, depending how dark I want the color to look. Just make sure you have everything primed and if you have to sand off an area prime it again. Non-primed areas will show up through the paint unless you use an extra can or two. Non-primed cars I've used an entire bottle, and priming the car first I use only half the bottle.
I've used Polly S acrylic clear, Boyd's High Gloss clear enamel, and automotive 2-part clear over these paints with no problems.
-Ron
Old 10-10-2003, 10:56 AM
dag65's Avatar
Silver will be awesome and give it some depth, and if the Boyds doesn't completely cover it up it really won't be too noticable in fact it may just be a slightly lighter blue and the silver will help the pearl reflect.
Paint your base coat as you would any other, just make sure it goes down smooth, let it dry rela good and then go for the Blue.
Good luck
Old 10-10-2003, 06:03 PM
EMAXX's Avatar
Re: Boyd's Paints?
Ok, thanks for all your help dag65. I'll keep you guys posted on how the build and everything goes. I'll probably paint is sometime this weekend. Again, thanks for everyones help.
Old 10-11-2003, 06:08 AM
steveboyd1414 steveboyd1414 is offline
I love these paints,they go on smooth and cover well.What i usually do is spray a little in an airbrush bottle and add a little testors thinner ,mix till it sprays smooth with an airbrush it really works well.
Old 10-11-2003, 06:31 PM
blueboost's Avatar
blueboost blueboost is offline
Re: Boyd's Paints?
Good luck
this is excellent advice IMO, and I think you will be more then happy with the results. I will do this a lot on models to get a better effect out of the paint I'm using as a top coat.
I think boyds paint is very nice paint, a little more difficult to get that perfect finish compared to tamiya so take some care. But the overall quality of the paint hue is superb the grape pearl and blue pearl are beautiful colors from experience.
if you'd like a reference pic, my blue silvia was done by applying 1 (2?) nice layer of boyds blue pearl over about 4 coats of testors dark blue. using this technique I got the darkness from the testors dark blue while still getting an interesting looking hue from the lighter pearl top coat.
here's the silvia thread, mines the first post, check out the paint.
http://www.automotiveforums.com/vbu...ght=silvia+meet
please help! -paint estimate helpme1234 Auto Collision Network 1 06-19-2010 07:11 AM
Switching To WaterBorne Automotive Paint LearnAutoBody Auto Collision Network 0 04-13-2010 08:10 AM
Pain with Paint!! aonewordname Type 1 1 08-29-2009 09:34 PM
1970 Chevelle Paint job xraab Classic Cars 1 05-24-2009 08:53 PM
New Paint Color "HELP" panteli2011 Thunderbird 3 05-01-2009 01:40 PM
