Old 10-08-2003, 07:32 PM
wilber24 wilber24 is offline
Unhappy 2001 Service engine light
Keep getting the service engine light after 25 miles. Have replaced a vent solenoid and the gas cap. Dealer cannot figure it out. Any ideas.\
Code has to do with the fuel system
Old 10-08-2003, 09:10 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 2001 Service engine light
If you can be more specific with the code, I'll try to help.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-09-2003, 06:24 PM
The dealer did not tell me the code but he said it had to do with the evaporate system, the vent solenoid they replaced was right above the gas tank.
Old 10-10-2003, 07:34 AM
GMMerlin's Avatar
I know stuff
Re: service engine light
Unfortunatly there are about 6 or 7 codes dealing with the evaporative emissions system.
To run most of the evap tests, the fuel level must be between 1/4 and 3/4 and there are some other parameters that must be met.
Knowing if it was a control code or a leak code would be very helpful.
GM WCT
PM Me for details
Old 10-13-2003, 06:36 PM
I will check with the dealer and let you know!
Old 10-14-2003, 08:18 PM
I talked to the dealer today and they said it comes up with a PE-440 code. He said something about trying to replace a cannister next.
Old 10-15-2003, 07:37 AM
GMMerlin's Avatar
I know stuff
The P0440 code is for a "gross" leak in the Evap system...pretty much this is the "gas cap code"
but it is also caused by other failed componants that can cause a large leak.
Ask them if they are using the J41413 Evap Presure/Purge diagnostic station (they will know it as the "smoke machine")
This machine injects a chemical smoke into the gas tank and evap system and helps pinpoint leaks.
With a P0440, it shouldn't be that hard to find a leak.
Using the Smoke machine and running the "Service Bay Test" with the Tech 2, there is no reason why the problem isn't fixed by now.
GM WCT
PM Me for details
Old 10-15-2003, 07:38 AM
GMMerlin's Avatar
I know stuff
Re: Re: 2001 Service engine light
Oh yea...some of the places I would look for a leak would be the tank seal, hoses to the vent and purge solenoids and make sure the FTP sensor is reading properly.
GM WCT
PM Me for details
Old 10-23-2003, 09:11 PM
The service manager told me he did the smoke test twice and could not find a leak. This time they dropped the tank and tried the test. No leak at the tank but they found a small one on a cannister, between the vent solenoid and the tank, they are replacing that tomorrow.
He says a lot of the problem is the tolerance is so low that the computer kicks out the 440 code on even the slightest of leaks.
Said he looks for GM to upgrade this and move the tolerance up.
Old 10-24-2003, 07:49 AM
GMMerlin's Avatar
I know stuff
Have them install the latest and greatest calibrations into your PCM...the upgrade may already be there, sometimes they upgrade calibrations and don't sent out TSB's on them.
GM WCT
PM Me for details
Check Engine Light..... Stinff Equinox 2 11-01-2010 11:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 11:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 03:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 06:16 PM
grand am engine light? confuoco1 Grand AM 1 04-01-2009 05:06 PM
