Old 10-08-2003, 03:36 PM
frankjc frankjc is offline
disable factory alarm?
i have a 99 blazer, with factory keyless/alarm....
the alarm (horn) sounds by itself, for no reason, when i lock the doors with the remote. i was wondering if i could disable it, and still use the keyless entry.
p.s., i have had the car to the dealer to try and correct this problem, but they couldn't figure it out....
thanks
Old 10-12-2003, 08:32 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
You'll have to test this to make sure the interior lights do not stay on. Locate the BCM. It is to the right of the gas pedel under the dash. THere will be a light purple plug. You'll see a light green wire, ground that sucker. That's your OEM alarm disarm. I think if that's always grounded, it can not arm itself. This is if infact you have the OEM alarm and not an add on that uses the car's horn.
Old 10-13-2003, 12:06 PM
Re: disable factory alarm?
it does use the horn, is this an add on?
i'm gonna go have a look at it......if it is an add on, can i just remove it?
Old 10-15-2003, 08:35 AM
Re: Re: disable factory alarm?
Well, then more than likely it is OEM then. If it is an add-on, you can simple rip it out.
Old 10-15-2003, 11:44 AM
fordin K fordin K is offline
try checking in your maual. gm made some systems with a programmable alert. meaning you can turn off or on the horn or open 1 or all doors at the push of the button. befire you ground anything check the manual first or give a call to the dealer.
Old 10-16-2003, 12:14 PM
Oh yeah. I guess didn't read the question like that. Does the alarm go off by itself after you leave the car or just beeps when you lock or unlock with the remote. Fordin is correct, you can do some programming on the OEM alarm yourself.
Old 10-16-2003, 02:04 PM
it goes off randomly, sometimes within seconds from pressing the remote botton to lock the doors,it has been to the dealer, they couldn't figure it out....now i loks the doors with the key, so that the alarm is not activated.
Old 10-16-2003, 09:45 PM
Re: Re: Re: disable factory alarm?
Well then I am unsure if it would be and OEM or add-on. If OEM, it should still arm itself with the key. I know it should if you lock it before you shut the doors. Oh well, just let me know what you find out.
How to disable factory alarm? 99 Tahoe ibbski Tahoe 0 11-11-2005 03:09 PM
looking to disable factory alarm madbodger 4Runner/GX470 3 11-26-2004 05:01 AM
how to disable factory alarm in a 93 laredo nart86 Grand Cherokee | Grand Cherokee SRT8 1 10-01-2004 08:41 AM
Need Help Disabling Factory Alarm fernjj Concorde 3 09-30-2004 11:29 PM
Disabling factory alarm Flic1 Jetta/Vento/Bora 2 06-17-2004 11:06 AM
