Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-08-2003, 02:45 PM
jmc813 jmc813 is offline
wet or dry nos?
im not to familiar with nos..i know mostly about what it does, etc..but i was wondering which is the way to go? i have a 95 civic ex?? is there any difference, etc. thanks in advance
edit:
Is this a good deal??
http://i1.ebayimg.com/03/i/00/be/6e/34_1.JPG
http://i9.ebayimg.com/03/i/00/bc/a9/c2_1.JPG
http://i21.ebayimg.com/03/i/00/bd/13/51_1.JPG
http://i22.ebayimg.com/03/i/00/bd/2d/86_1.JPG
here is what i get:
Nos Brand Dry shot Nitrous system
2 10 LB bottles with Hi Flo valves
14 foot of line for front engine cars
5 Jets 25 50 65 75 Horsepower
Special mr2 install line for mid engine cars
NOS part no. 16020 powershot solenoi
Brand new full throttle switch
NOS 10 LB bottle Brackets
all for $299
is there anythign missing in that deal??
Old 10-08-2003, 03:01 PM
Jeff C's Avatar
Jeff C Jeff C is offline
That seems like a good deal. However, for $50 more, I got a bottle heater and nitrous presser guage. I have Zex too. Not sure on which is best.
Here is what I have come to the conclusion of based on reading...
-75-80 shot and less > single fogger dry setup
-80 shot and more > direct port wet setup
-1989 Honda CRX Si, B18A Pic FOR SALE
-1998 Honda Accord EX Sedan 5spd
-1981 Chevrolet Silverado, shaved and bagged Pic
Old 10-08-2003, 09:54 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
IMO dry kits are terrible! But some people like them. However the one thing that I did not see in thre pics is the fuel pressure riser that has to bump up the fuel presure when the nitrous is flowing. With out that the kit will destroy your motor. I would suggest getting a fuel solenoid and a fogger nossle and go wet.
Old 10-09-2003, 02:06 AM
hondaracer hondaracer is offline
Re: wet or dry nos?
Wet is definitely better. Running straight nitrous (dry) is very dangerous and much more stupid, is a way you can put it. But I woul also get that bottle heater too. N2O must be kept at certain tempaeratures for maxmimum performance output. Also I like the idea of having an electric bottle opener, its really nice to just open up and close the bottle at any time with the flick of a switch and not having to manually do it everytime.
Old 10-09-2003, 01:38 PM
Jeff C's Avatar
I have heard bad things about wet single fogger nitrous systems having the fuel puddle up and then igniting. If you are staying around a 75 shot or less, I would just get a dry system. Zex has not sold millions of their dry systems because every car blew up that uses it.
Old 10-09-2003, 03:33 PM
whtteg's Avatar
Re: wet or dry nos?
I have been using one for 3yrs now, and i have freinds that have been using then for a long time too. And nobody has had any problems with them. The thing that causes the fuel puddle is when you spray with the bottle pressure below 800psi. A bottle warmer and pressure gauge will take care of thet problem. Also I know of 3 people that have had the ZEX kit here and all of them blew their motor within 1yr. And that was with 50hp shots and i have been running 65-80hp shots for 3yrs and my compression is almost to spec, which is really good for a motor that has 130K miles. Zex dry kits are terrible IMO. And BTW all of the guys who had the zex kits had detonation problems in the #3 cylinder.
Old 10-09-2003, 04:09 PM
Jeff C's Avatar
Re: Re: wet or dry nos?
I guess it just depends on people behind the switch. Do you happen to know if they had an aftermarket ignition, colder plugs and such or did they just slap it on and go?
Old 10-09-2003, 04:58 PM
boosted331 boosted331 is offline
Bottle pressure has nothing to do with fuel pudding or not in a wet system. Nozzle placement and intake manifold design have everything to do with puddling. Don't worry about puddling on a honda motor, the intake manifold is a pretty straight shot right into the ports, you shouldn't have any trouble. It's with a long runner intake like on 5 liter mustang where theres curves and bends that you can get problems with puddling.
Old 10-09-2003, 05:02 PM
whtteg's Avatar
Re: Re: Re: wet or dry nos?
You don't have to have an aftermarket ignition kitto run a 50 shot. And yes they had colder plugs, one of them had the three prong Zex plugs that are 2 steps colder, which is more than adequate for a 50 shot. Lookl at it this way you are reling on the IM to distribute the nitrous evenly but it will not and most of the time #3 cylinder will get more nitrous than the others, but the fuel injectors are only suppling enough to cover an even distribution of the nitrous and this causes a lean condition in #3 cylinder. Plugs, ignition etc none will help you when you don't have enough fuel for the nitrous! But when you use a wet kit it solves this problem by suppling the extra fuel and atomizing it with the nitrous so even when the cylinders don't get the same amount of nitrous it is still the right ratio of nitrous to fuel. See my point? I have been using nitrous for long time and know alot about it, trust me wet is better if you are planning on using it much. But knowledge is the key with nitrous period! You have to know how to use it and how to respect it!! And you have to kknow exactly what is happening when nitours is inducted into the motor ( ie. you have to know how it works).
Old 10-09-2003, 07:04 PM
93weed_eater's Avatar
93weed_eater 93weed_eater is offline
Send a message via AIM to 93weed_eater
is nitrous express a dry or wet system?
Old 10-09-2003, 08:02 PM
whtteg's Avatar
NX is a wet kit
Old 10-09-2003, 09:27 PM
cool
i think when i get my next vehicle ill go spray. don't have the cash for boost
Old 10-10-2003, 10:19 AM
Jeff C's Avatar
Re: Re: Re: Re: wet or dry nos?
That is why I personally converted my Zex dry single fogger into a direct port setup. It wasn't hard and its probable a good idea for other people.
I still dont know about that fuel puddling of a single fogger wet setup. :shrugs:
Old 10-10-2003, 02:58 PM
whtteg's Avatar
Re: Re: Re: Re: Re: wet or dry nos?
...I still dont know about that fuel puddling of a single fogger wet setup. :shrugs:
I am 24 yrs old and ever sense I have been around and involved with cars, which is most of my life I have never seen that happen to anyone. I think if it did happen to some people it would be because they installed the nossle too far away from the throttle body or they had a way too large fuel jet in for the amount of nitrous they were spraying. I still don't like the dry kit because even if it is direct port, what controll the amount of fuel added? Honda's have MAP sensors not MAF sensors. So the Map is not going to pick up on the nitrous and even if it did the oxygen contained in the nirtous does not get released until like 500 degrees or something. All that is controling the amount of fuel is the pressure riser that uses nitrous pressure to raise the fuel pressure, but it can only go so far! The fuel injectors will only spray so much fuel and the duty cycle needs to be changed and not the fuel pressure as much. Can you see my points? These are some of the reasons I always advise people to go wet instead of dry.
Old 10-10-2003, 03:08 PM
Jeff C's Avatar
Re: Re: Re: Re: Re: Re: wet or dry nos?
Well, you aint got too many years on me. However, you probably do have more nitrous years on me. You are right, the ones that I have heard of puddling up with fuel might have been install by careless idiots who did not know their butthole form a groundhog hole. And you are right about having to rely on the pressure riser to add adequate fuel. However, with wet kits you have to rely on the solenoid to add adequate fuel and well solenoids go bad. You just never now each way I guess.
04 Hemi, Would DRY NOS work? xfeejayx Ram Pickup | Ram SRT10 1 04-25-2008 07:59 AM
Wet/Dry kit dsmkid95 Off-Topic 7 04-21-2005 03:48 PM
