Old 10-08-2003, 12:40 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Question Difference in engines???
Ok ppl I have a '88 Civic HB std. that has a d15b1 in it and I have a '91 Civic HB std. that has a d15b1 in it. I noticed on the '88 that the o2 sensor is right at the top where as my '91 isn't. What is the difference in the two engines? I was trying to get a clutch for it, but the part numbers are different for the years. Just about all the part # are different with these engine yrs.
For those about to say "DO A SWAP" I plan on doing one, but its not in the budget yet. So please spare me. I don't want to hear it. I just want to know the difference in the year engines and why the '88 is so different. HOLLA!
***(Just a little info) I got 2 new jobs. I will be working at Advance autoparts PT and I just got a new bartending job that starts in Nov. My swaps maybe sooner than I thought. I may not have to sell the b18b. Wish me luck.***
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 10-08-2003, 12:43 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: Difference in engines???
Well for power wise i believe its the same. I think the clutch have different splines for the 88 compared to the others.
Old 10-08-2003, 01:10 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
I know that when I changed the transaxle in my 91 STD I had to buy a different clutch to go with the new transaxle. I was under the impression the that was because it was from a DX instead of a STD. I know the imput shaft on the transaxle is different from STD to DX & SI, but I don't think it has to do with the years. Your best bet is to count the splines on the imput shaft of the transaxle or if you have the clutch from bothe see if the disc's are interchangeable.
Check out my car here My 91 Hatch
Old 10-08-2003, 01:17 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
that's a honda 4 u.....always making little changes that make big differences
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 10-08-2003, 01:36 PM
T-Mo's Avatar
Re: Re: Difference in engines???
Ok so anyone know the number of splines it has 23 or 26? I need a new axle also. Will my best bet be to pull one off of a 88 civic?
'93 Honda Civic EJ2
Old 10-08-2003, 01:39 PM
BLU CIVIC's Avatar
調整器
Re: Re: Re: Difference in engines???
yup.......
The name's Adrian
2011 CR-Z - Stock
Old 10-08-2003, 09:49 PM
T-Mo's Avatar
Re: Re: Re: Re: Difference in engines???
so about the number of splines. Anyone know. I have a chance to get the clutch and axle new and for the low low.
'93 Honda Civic EJ2
Old 10-08-2003, 10:50 PM
GTA's Avatar
GTA GTA is offline
Whee..
Re: Re: Re: Re: Re: Difference in engines???
the 88 trannies are 21 spline. The 89-91 are 20 spline.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 10-08-2003, 10:52 PM
fredthedragon's Avatar
fredthedragon fredthedragon is offline
Send a message via AIM to fredthedragon
all stds have 23 and all d seriese trannies have 26 for the trannie i had some bum at advance that the 23 spindels were on both sides and ended up selling me the wrong part and a week w/out a car and work.
just tell advance you have an std and they will give you the right axel, well technically tell them you have an std model civic they'de look at you funny if you told them you needed axels for your std.
I'm no street racer nor do want to be, my goal is a fun car... that leaves SUVs in the dust.
current car: red 90-civic-STD-hb
with dx trannie, ecu, shift knob, & rear seats.
i hate my vynil seats.
p.s. i am once again with computer, please forgive the one year leave of absence.
Old 10-09-2003, 12:17 AM
91civicDXdude's Avatar
the 88-89 STD had the HF/CX style manifold..so that alone would tell me it has less horsepower than the 90-91, since it had the DX/Si style 4-1 factory manifold.
Old 10-09-2003, 01:28 AM
T-Mo's Avatar
I am confused??? GTA and Fredthedragon???
'93 Honda Civic EJ2
Old 10-09-2003, 03:29 AM
GTA's Avatar
GTA GTA is offline
Whee..
i was talking about the clutch. he is talking about the hubs and axles.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 10-09-2003, 11:40 AM
T-Mo's Avatar
ok, now I see. Thanks folks.
'93 Honda Civic EJ2
Old 10-09-2003, 11:22 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
use a 90-91 manifold on the 88 motor, because the 88 manifolds lower section is actually the cat converter, so if you use the 90-91 manifold, you will effectively have removed your cat, with no evidence it was ever there.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Differences between '05 and '06 1.6 Engines? edr_bug Aveo 0 08-07-2009 12:51 AM
different engines Joseph K Lancer 7 08-24-2004 03:04 AM
Superiority of different engine designs perky_intnl Engineering/ Technical 12 05-04-2002 04:25 PM
BMW - badging and different engine models BraN 3 Series 2 12-07-2001 08:12 PM
