Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 10-07-2003, 09:29 PM
Teckert Teckert is offline
No heat
My van blows cold air when the temp is turned to hot. I tried replacing the thermostat, bleeding the air out of the system (although I don't know if I did it correctly, I kept opening the two bleeders while the engine was running and the thermostat was open), and looked under the dash and noticed a rotor turning when I change the heat setting from hot to cold. Does anyone have any suggestions?
Thanks,
Todd
Old 10-09-2003, 10:23 PM
jimarmijo jimarmijo is offline
the lever that changes it from hot to cold has a cable that goes to a valve connected to the heater hose under the hood if it's not fliping that lever over then you wont get any heat. most of the time you can pop the hood and flip that lever over with your hand. My car did that. When I would flip the lever over I would get good heat but if anyone inside the car pushed the control back over to cold, the lever under the hood would move back to the cold position it just wouldn't change back to hot from inside the car
Old 10-10-2003, 08:03 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: No heat
Thanks,
Todd
First check and see if both heater hoses are getting hot. If so than coolant is flowing through the heater core and you have a temp door problem.
If one hose is hot and the other cold than most likely you have a restriction in the heater core or an air pocket in the cooling system.
Disregard the above post, your vehicles inside temperature is controlled by a temp door inside the heater case.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 05-10-2004, 08:46 PM
lerndoutofnesscity lerndoutofnesscity is offline
If you have no heat but air is blowing.check all of your heater settings (Defrost,upper and lower vents) and see if you can change them. If non of them work or it seems to go back.Check the heater control switch (under glove box.Mounted to air duct) This switch it air activated and can stick. I found on at the junk yard for $20. Fixed my problem. Hope it helps you.
Old 05-10-2004, 10:18 PM
The switch is air activated (you'll see a bunch of clear tubes). And I found one at the junk yard for $20.........Sorry about the mistakes
no heat/mixed heat jbmx4life Grand AM 7 02-11-2006 01:37 PM
Manage Your Heat!!! Manage Your Heat!!! Manage Your Heat!!! Manage Your Heat!!! eahockeygod Metro 3 01-10-2005 08:00 PM
No heat when stationary, heat when moving. girardmn Sable 3 03-22-2004 08:50 PM
Heat then No Heat randyman C/K 3 12-11-2003 02:25 PM
