Old 10-06-2003, 09:56 PM
SiR_G_Civic SiR_G_Civic is offline
Send a message via AIM to SiR_G_Civic
Help with my swap please!
I swapped out my d16 for a b16, now i swapped my b16 for a b18, however i cant get the b18 to run. i get spark, gas, air, the fuel pump turns on, it turns over, but doesn't want to start, iv put all the grounds back on, but i feel that i may have missed a couple, i onyl put the tranny one on and the valve cover one on. i'm running a p72 ecu, hoever there are 2 wires and one plug running from my ecu to the engine bay, one goes to the vtec solenoid, and the sensor connects to the senors on the back of the block, under the intake manifold. what am i missing, i replaced the cap and rotor, with 94 integra ls/gsr parts, and got gsr wires/plugs. any ideas, please help, i need to get this thing going
Thank you in advance
Mike
Old 10-06-2003, 09:58 PM
oh ya.. timing is correct also
Old 10-07-2003, 06:31 AM
anyone? please
Old 10-07-2003, 06:20 PM
no one knows anything about swaps hjere?
Old 10-07-2003, 06:36 PM
csaddict's Avatar
csaddict csaddict is offline
Well in theory if you have spark, fuel and compression your car will run. You must not have one or all at same time. Do you even get a pop when it tries to start? Try giving it a quick squirt of starting fluid and if it pops then your injectors aren't working, or not enough fuel pressure or at least a fuel related problem.
[size=1/2]96 Civic CX Hatch
1.6 Non VTEC
Full length CAI
Custom Catback Exhaust
Short throw
H&R stage II springs
Tokico Illumina adjustables
front upper,rear upper,rear lower tie bars
ST front and rear sway bars
BOOSTED![/size]
Old 10-07-2003, 07:03 PM
Blowncivic1320's Avatar
Blowncivic1320 Blowncivic1320 is offline
Hey u wanna get rid of the b16 u took out?
-Andrew-
Old 10-07-2003, 08:29 PM
well i'm thinking of trying that, and abot the b16, all i have left is the JDM b16a tranny, with an ITR final drive gear, pistons, an ITR intake manifold, and other random components
Old 10-07-2003, 10:08 PM
I found that the injectors arnt opening, if i find them to be good, what can i do about wiring, or what does it mean?
Old 10-07-2003, 10:40 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
check the fuel line from the passenger side. My friend had his in the wrong spot and it wouldnt run either. Just a thought...
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
i put a new head on my 88 civic hb dx now i need help with timing...PLEASE HELP!!! boyertownMidnight3 How-To's and Walk-Through's 0 08-13-2005 09:59 PM
Help with Swap please euroAccorDeuro Accord/TSX/Accord Hybrid 4 08-07-2003 08:54 PM
Help with Interior PLEASE CivicSkater Car Audio 3 09-24-2002 12:03 AM
NEED HELP with hubs PLEASE! SilverLotus340R Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 8 09-09-2002 09:00 AM
Car audio Installers help with HU please. overdrive380 Car Audio 16 06-11-2002 09:13 AM
