Old 10-06-2003, 08:17 PM
SURENO SURENO is offline
H22 Swap How To
Im Finally Getting Ready To Swap My Usdm H22 Into My 94 Honda Accord Lx. Im Also Swapping From Automatic 2 Manual. Hopefully Everything Goes As Planned. Just Want To Know If Anybody Knows A Good Web Site With A Good Step By Step How- To On This Swap. Also Can Anybody Give Me Any Heads Up On Problems I May Encounter Along The Way.
Old 10-07-2003, 09:08 AM
akina_speedstars akina_speedstars is offline
Re: H22 Swap How To
I think the recent issue of Sport Compact Car has a "How to" engine swap article for Accords. If I recall, it was for a plain 4 cyl to VTEC 4 cyl swap.
Old 10-07-2003, 12:20 PM
h22 swap how to
thanxs for the reply ill take a look at it.
Old 10-08-2003, 08:59 PM
jsr1200 jsr1200 is offline
Re: h22 swap how to
i'm about to do the same thing in a few months also w/a built 97' h22a.I know that the h22 is actually the motor intended to come w/ the accord so it should fit w/ no probs.But the recent article on an h22 swap says the engine mounts will ne persuading.i think that they did this on an Lx and not the vtec equipped ex.So depending on what you've got you may or may not have a prob i guess.Oh and you'll have to change the ecu and harness.
Old 10-09-2003, 10:35 PM
H22 Swap How To
I Have Another Question Though. Does Any One Know Of A Company Who Sells A Motor Mount & A Harness Kit For A Pain Free Swap. It Would Be For A 94 Accord Lx. Does Something Like This Even Exist.
Old 10-20-2003, 09:13 PM
broketrannyaccord broketrannyaccord is offline
Re: H22 Swap How To
No it doesn't exist because there is no such parts neccy. its plug and play. buy a case of your favorite brew, invite a few mech. inclined friends over for the weekend, steal/borrow someone's bad ass snap-on or mac tool set and get ready for a fun weekend.
Old 10-20-2003, 09:18 PM
castback's Avatar
castback castback is offline
Send a message via AIM to castback Send a message via MSN to castback
Hasport has the engine mounts that you might need. you should replace the old ones
Old 10-21-2003, 12:48 AM
92lx 92lx is offline
check out my signature.
The H22 swap in the SCC article was horribly done, they really messed up on a lot of things. (see the many threads on pretty much every honda board since then *laughs*)
- Nathan
Old 10-24-2003, 01:45 PM
nozpwrdcrd2000 nozpwrdcrd2000 is offline
motor swap
H22a.org has info on a swap for your gen. Good luck! I just got a swap in August. OBD2 h22a4 in a 2000 4dr lx. SIR-T changeover. It fits pretty nicely. Just a couple of hints. Get a port n polish and build upgrades, if you can before you swap engines. You'll be glad you did.
Expect some setbacks, little things here and there.
Drind and polish the engine before insert. It will look better.
I had to wait 2 mnths for a wiring harness but I finally got it and the car runs great. Inform yourself about a code 12 engine light code which is the EGR VALVE code. The engine light seems to turn on frequently when the car rises temperatures. It has to do with the richness the car is running and the emissions, I think. I havent figured out how to correct for that but I thing an EMS stand alone Engine Management System will do the trick. I plan on building the internals and droppng a turbo for a turbo/nitrous setup so more money more headaches and theres no telling how fast I'll go? good luck with your swap.
Old 10-28-2003, 04:19 PM
burn000 burn000 is offline
Re: motor swap
i have a civic with an h22 .... jdm one .... and im getting a code 12 flashing... no one seems to be able to tell me y ... anyone can help..... e mail me back please [email protected]
Old 11-04-2003, 03:35 PM
wagsaccordsir's Avatar
wagsaccordsir wagsaccordsir is offline
Try these sites!
http://www.h22.org
http://members.aol.com/accorddrv/h22.html
http://www.extremeredline.net/accord/automanual.html
PEACE
~J
MY ACCORD ON KENWOOD'S PHOTO GALLERY
MY ACCORD ON CARDOMAIN
"CHEAP THRILLS"
I DON'T CARE HOW MANY SKY DIVES YOU'VE GOT. UNTIL YOU'VE STEPPED OUT INTO COMPLETE DARKNESS AT 850' WEARING 95LBS. OF EQUIPMENT AND 68LBS. OF PARACHUTE. YOU JUST HAVEN'T LIVED.
ARMY AIRBORNE!!!
Old 02-09-2004, 08:59 AM
juju4uofa juju4uofa is offline
Re: H22 Swap How To
H22a.org has a good description of the installation process for 4th and 5th generation accords. As for the motor mounts you can use the stock mounts from the accord except the drivers side mount, which you can use off the prelude
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 11:43 AM
how H22 Swap into a del sol 93 willsol How-To's and Walk-Through's 1 07-20-2005 09:30 AM
How much does a standard h22 swap cost for a 93 accord ngc604 Accord/TSX/Accord Hybrid 1 07-15-2004 08:54 PM
how much for a h22 swap? imran840 N2O | Turbo | Superchargers 8 05-14-2004 01:55 PM
cheap coilovers for how long? H22 swap Q also 94tegRS Accord/TSX/Accord Hybrid 5 08-12-2003 02:28 PM
