Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 12-05-2001, 02:29 PM
Nismoboy1's Avatar
Nismoboy1 Nismoboy1 is offline
Send a message via AIM to Nismoboy1
For all those lowered P11's who needs shocks...
Koni will have a set available by 12/20/01. Note: these will only be the Koni Specials aka Reds. Adjustable dampening only by taking it off the car, compressing it and then turning it counter-clockwise. The dampening may not be aggresive enough for high spring rates but enough for just plain lowering springs. These will have Koni's lifetime warranty as stated on their website "KONI street shocks carry a lifetime warranty to the original purchaser for as long as you own the vehicle." unlike having the unwarranted Maxima shocks for the rear. Maxima rears are NOT made for our cars, therefore not warranted, but these are. So Koni will warranty these, as long as its your car and its on a US P11. A "Warranted" Sport set maybe available soon but no ETA is set. Part #'s and prices are as follows...
F - 8040-1127 - $95 Each
R - 8040-1220 - $119 Each
check with www.velocityresources.com for availability and ordering info.
thanks to Velocity Resources and B-Boogie for the contact info.
damn, i sound like a salesman
John H.
2001 Infiniti G20t - Aspen White Pearl
For Sale: 18" Gold Axis Se7en's and Eibach Pro-kits also for a G20 P11. Check the Infiniti G20 Classifieds Here
***My G20 - Click Here***
Old 12-05-2001, 02:46 PM
b-b00gie's Avatar
b-b00gie b-b00gie is offline
Banned
Send a message via AIM to b-b00gie
Well, thats dissapointing... was hoping they'd be the yellows.
Old 12-05-2001, 02:55 PM
Nismoboy1's Avatar
it'll be good for most of us here who can't afford a set of coilovers and better for those who already have lowering springs on their p11...but a sport set would be nice
John H.
Old 12-05-2001, 03:00 PM
Nismoboy1's Avatar
btw, Jason said their is a sport version of the fronts that Koni will warrant on a USP11 but no rears as of yet or ever...especially since I've seen that rear part number floating around for a while now and they haven't made a sport application for it yet. Looks like the Reds are all we're getting, let's see if kyb responds
John H.
Old 12-05-2001, 04:19 PM
donsster donsster is offline
Send a message via AIM to donsster
I have the 8040-1127s on the front of my P11 and they're yellows! The 8040-1220 is on my car and is a red. The 8040-1127 should also fit a P10.
There shouldn't be any significant size difference between the 8040-1242 (rear yellow) and 8040-1220 (rear red).
How would Koni know what car you installed a shock on if you don't tell them?
Can anyone independently verify this?
Shox.com said a year ago that they could get these shocks.
Don McLaurin
Old 12-05-2001, 06:55 PM
b-b00gie's Avatar
Banned
I had the 1127 fronts and 1242 rears....
wonder how the 1220 rears compare to the 1242
Old 12-05-2001, 06:58 PM
b-b00gie's Avatar
Banned
Donster,
What spring rates are you using on your GC's and how do you like them?
When I got mine I have no idea what the rates were, I didnt even know it was an option... I was a newbie then anyhow.. the ride was OK, except for that darn squeaking..
I ended up selling my setup and getting the Teins. I think I'd like to swap back though..
Old 12-06-2001, 02:08 AM
ty423's Avatar
ty423 ty423 is offline
Send a message via AIM to ty423
hmmm....maybe I will get a set of Koni's but it really really sucks that you can only adjust them out of the car with the spring out. Thats just a pain in the ass. I sure hope KYB comes out for the rears. It will definitely be cheaper too.
Old 12-06-2001, 09:20 AM
Nismoboy1's Avatar
[quote]Originally posted by donsster
yep tru, the p10 and p11 fronts are interchangeable, exact same part number, reds or yellows
size difference, most likely no, but spring perch height, yes...the 1242's have a spring perch that's a little higher than standard, which may actually raise your car little, but the 1220's have a adjustable spring perch, the bottom one being exactly standard height and the top one is 20mm higher.
they probably wouldn't know, but i guess thats what you would call the honor system lol
no doubt, Velocity Resources could have gotten them too, these part numbers have been floating for a while now, but i think the reason why no one has offered them to p11's in the US market yet is because Koni hasn't approved the fitment and warranty until now :flash:
John H.
Old 12-06-2001, 12:52 PM
Originally posted by b-b00gie
Donster,
I'm pretty sure I have 380 up front and 340 in the rear. Ride is still comfortable, and handled well on the track too. Yes, these are way higher than the P10 GCs, but since the P11 is heavier I guess you can get away from it.
I understand now about the spring perch with the 8040-1242. But I'm surprised that it would make a difference with the adjustable height GCs.
Has anybody tried GAB shocks with GCs on a P11? GABs are known to be really stiff but they are externally adjustable.
I keep mentioning it, but the Motivational Engineering rear upper mounts will help you drop the car and at the same time give you more wheel travel.
Don
Old 12-06-2001, 01:55 PM
Nismoboy1's Avatar
prolly wont make too much a difference for those with GC's, cause those people can just lower their GC's a little to make up for the raise on those 1242's. Others with just plain lowering springs have to go with the 1220's for correct fitment.
but that brings up an interesting question for those GC owners out there, which shock will give you more travel? knowing now both will fit the rear(only applies to GC owners). the 1242's or the 1220's?...you gotta consider the 1220's also have a adjustable spring perch...just a question for those out there with GC's to ponder
John H.
Old 12-06-2001, 05:48 PM
2001G20 2001G20 is offline
OK...I already have Eibach springs on my P11, now if i get the konis will it lower my car anymore than it is?? Because I would like the car to be a little bit lower than what it is now. I was considering Teins...would they make my car lower than w/ the Eibachs?? Thanks
Old 12-07-2001, 07:05 AM
b-b00gie's Avatar
Banned
I dont think the Koni's would lower you anymore.
The Teins have 3 height settings which are aproximately... 2", 1.8", and 1.5"
Old 12-07-2001, 08:55 AM
Mrcoilover Mrcoilover is offline
Might even raise you a tad b/c your stock shocks are a lot softer than the Koni's will be.
*Mod List*
2 JL audio W3 12's
Rocksford Fosgate 600w amp
Tein type NA (1.7)
Nokya Arctic purple headlight bulbs
Rims coming soon...
"I always ride dropped, how bout you?":finger4:
Old 12-07-2001, 04:11 PM
ok thanks...I guess I wont be getting the konis then bcuz I want my car lower than what I have with the Eibachs
for all those who have ever worked retail...or haven't s14silvias14 Stress Release 18 07-27-2005 01:02 AM
for all those who are power hungry... speeddemonGtV6 Tiburon | Tuscani 2 01-02-2005 05:39 PM
For all those who say a FWD can't drift Tony Initial D 55 09-27-2003 08:26 AM
for all those people who wants "coilovers" G22DET Suspension 9 04-25-2001 11:18 AM
