Old 10-01-2003, 08:59 PM
conan2 conan2 is offline
Unhappy heating
i have a 1999 taurus with a 3.0 engine it has had a new heater core,thermostat,and the system has been flushed,it also has the climate control system.my problem is i get good heat coming out the vents after about 10 minutes but only warm heat coming out of the defroster,can you help im going crazy and its costing me a lot of money.thanks
Old 10-02-2003, 11:07 AM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
The A/C system operates when the defroster is on - this is to de-humidify the air being blown on to the windshield and prevent fogging. See the Owner's Manual.
There may be a problem with the duct system; like a vaccum solenoid is leaking or something. The heat duct door should be fully open, IIRC.
If you have the electronic Climate Control, there is a self-diagnostic program that you can run, but I don't know how to actuate it on the '99 Taurii. A real competent shop should be able to help you out.
Lastly, if you're already into spending money, go to www.helminc.com and get the factory service manuals. Those books are 4 inches thick and are WELL worth the cost! They will cover things like starting the self-diagnostics on Climate Control.
Good luck, and keep us posted.
Old 10-03-2003, 08:33 PM
mikeo550 mikeo550 is offline
Lightbulb sorry
well the good news is you knocked out half the things you were going to need to replace in the future... the bad news is once the heat stops working it never comes back... try a water pump... vacumm... other than that bundle up!
Old 03-02-2004, 04:40 PM
wwest wwest is offline
Re: heating
New design by idiots.
Somebody decided that using the A/C to dehumdify the defrost/defog/demist windshield airflow would always be sufficient to remove and prevent condensation.
It isn't.
When you want to use defrost/defog/demist turn the heat setpoint UP first.
Below about 55F it is only by EXCEPTION that the A/C is efficient enough, depends on the relative humidity of the incoming airside airflow.
no heat/mixed heat jbmx4life Grand AM 7 02-11-2006 02:37 PM
Manage Your Heat!!! Manage Your Heat!!! Manage Your Heat!!! Manage Your Heat!!! eahockeygod Metro 3 01-10-2005 09:00 PM
No heat when stationary, heat when moving. girardmn Sable 3 03-22-2004 09:50 PM
Heat then No Heat randyman C/K 3 12-11-2003 03:25 PM
